Two different brake differential pressure valve connectors?
Did GM use 2 different style connectors for this? The connector that fit the CPP proportioning valve I took off will not fit the plug on the original distribution block. I'm pretty sure the CPP valve came with a connector, as the wire is spliced, but I cannot find any other connector besides this one which is wrong.
This is what I'm trying to put back on...
Brake distribution block
And this is what came off, you can see the connectors can't be the same.....
Proportioning valve
And this is the only connector I can find....
Connector
Proportioning valve
Connector
sx455raidercelticfan
Brakes/Hydraulic Systems
Mar 19, 2023 10:09 AM
