Info on hold off valve and proportioning valve
Old Mar 18, 2023 | 09:15 PM
sx455raidercelticfan's Avatar
Hi guys so I’m on week 3 of my weekends I’m having no luck at all!! I had to cut my brake line because of my headers, I’ve bought a new booster and proportioning valve now I’m reading I need a hold off valve
do I need a hold off valve?? It’s a 70 cutlass with stock 455, front disk rear drum
Old Mar 19, 2023 | 07:50 AM
Is this a factory disc brake car or was it converted?
The factory did not use a proportioning valve from the factory. Despite what you may read, the hold-off valve is not a proportioning valve, it is plumbed into the front brakes to "hold off" application of the discs for a fraction of a second until the slop has been taken out of the linkages in the rear drums. On the 1967-70 factory disc brake A-body cars, Olds balanced the front/rear brake bias by changing the diameter of the rear wheel cylinders. Factory disc brake cars used smaller (yes, smaller) rear wheel cylinders to prevent premature rear wheel lockup. The distribution block on the frame was the same as the one used on four wheel drum cars and has no internal valving, again contrary to what you may read.
All aftermarket disc brake conversions use a combo valve similar to what the factory used starting with the 1971 model year. This combo valve COMBINES (thus the name) the functions of the distribution block, hold-off valve, and proportioning valve into a single unit to save assembly cost and reduce potential leak points. If you have a combo valve, you don't want or need an additional metering valve.
Old Mar 19, 2023 | 09:40 AM
Should be obvious to anyone reading/following you meant to say "1967-1970" (just a clarification point).
Old Mar 19, 2023 | 10:09 AM
But that's what it says... NOW.
Thanks for catching that.
wr1970
Jun 25, 2021 05:47 AM
bry593
Brakes/Hydraulic Systems
Apr 4, 2019 10:21 PM
servexcell
Aug 4, 2018 11:17 AM
1k442
Jul 3, 2017 10:05 AM
mmurphy77
May 2, 2011 08:09 PM
