Original decal removal on Rallye 350...
Old Mar 29, 2026 | 05:33 AM
jensenracing77's Avatar
Is it possible to remove the decals on an original paint car and not damage the paint?
Old Mar 30, 2026 | 08:27 AM
zl1 camaro's Avatar
SURE, use a hair dryer and keep the dryer moving back & forth over the decal to soften the glue as you pull it off slowly. Dont keep the dryer in one area. Here is the problem, once the decal is removed the paint under this will not be faded. So you will see where this decal was.
Old Mar 30, 2026 | 12:03 PM
69HO43's Avatar
The only real issue with the fading is that if you're not repainting the car and only replacing the decals it can get dicey. If they're exact sized repros, they'll likely never be noticed if placed in the same spot. But if they're not, they'll show a huge difference in the faded/not faded areas. Also, it'll show if you try to "fix" the placement of the decals from any potential misplacement from whoever put them on originally. Repainting? No problem.
Old Mar 30, 2026 | 03:37 PM
That is what I am worried about, If the new decals are not the exact same size it will show non faded paint around the new decals. Installing the decals is easy but taking the old ones off I am more worried about. I will highly likely never pull the original decals off but just asking the question. The pictures I am getting of the car i am looking at, I think the decals will be nice enough to fit the aged look of the rest of the car.
Old Mar 30, 2026 | 03:46 PM
otto72's Avatar
Dont over think it Eric... trust in the process. Have fun and good question, you know what you have that will be the proof needed period
Old Mar 31, 2026 | 01:27 AM
Sounds like you're getting quite a collection, Eric.
Old Mar 31, 2026 | 03:33 AM
Had a major change of plans. I will fill everyone in at a later time.
dragline
May 27, 2018 04:25 PM
willysman
Jan 3, 2017 05:13 PM
jharsh
Dec 30, 2016 01:25 PM
airborne1942
May 23, 2015 06:48 AM
sicky olds
Jun 17, 2012 12:36 PM
