That is a Genuine GM company name aftermarket supplier. That part number (14090908) is used on a plethora of GM products and not specifically as an oil drain plug - it will fit other areas of many GM engines, assemblies, etc. It "might" be the correct gasket - I'm not 100%.
I think you work in a parts store? Try to cross-reference this number (below) 559563. It almost looks like on the image of the bag you posted there is a number which begins with "5" located below the 14090908 number but is obscured/covered up by that label.
And, I'm not disagreeing with anyone, it's likely a good "GENUINE GM" (aftermarket) part number i.e. most likely will work. I'll note the original (as noted in the parts book) was copper.
