View Full Version : General Discussion
- 72 W-30 Convertible
- Left tail light assembly needed
- 394 married to 700r4
- Passenger side rear window w/manual crank
- 1966 98/88/Starfire vacuum power door lock restoration
- Rochester 4GC carb
- 455 Valve Covers
- Fuel Gauge '71 442
- What was the application for #8 heads with A.I.R. ports drilled?
- L74 QB code
- Apparently Not All Crash-Test Cars Go Right to the Crusher
- Oldsmobile Historic Services?
- Lost Muscle Cars Looking for a 69 442
- Fiberglass Recommendation for front Bumper 65 Olds
- Can vacuum motors have a vacuum leak and still work?
- Original Selling Dealer: B&A Chevrolet, Toronto
- Real 1965 442 Fremont Car?
- Need help finding reliable mechanic in Beaverton OR
- 1969 Hurst/Olds History car number 517
- Which speedometer is gear is correct for a 70-442 w/manual trans & a 3:23 gear?
- Exercising the car
- Restoring a 1966 98 holiday coupe
- Nose number alignment '70 442
- Auto Art 66 442
- Waterpump rebuilder...plus questions
- Speedometer lube recommendations
- Car show poster
- I’m life long Olds fan
- Alternator builder needed
- Choke stove Tube
- 1970 Rear Window Windlace
- Rolex24/Michelin Pilot Challenge
- A Rare Olds for your enjoyment!!
- Trans Tag Decals / FYI
- Blower mot
- Shippers?
- Why does everyone install oil sender at an angle?
- Information about my Cutlass?
- Remote oil filter
- 1970 GM Logistics Train. Who’s W car?
- Need some suggestions regarding my cam timing.
- Sealer.
- trunk torsion spring installation
- James Garner driving Delta 88
- Power Tour 2026
- Tri Carbs R Us
- Smokey yunick secret chevy 327 small block
- Notching the center divider on a 7111 intake
- Death of Daniel Kanter
- Fuel starvation at highway speeds on my 1953 Super 88
- Seems to me Olds engines always last longer. Why?
- Steering wheels.
- 08 Dodge Avenger strange starter issue.
- Death of David North
- A moment to rant..
- Early 70 power disc master type?
- Pre-Installation Checklist for "Fully Assembled" Heads
- Where to buy a good quadrajet carb?
- need help identifying a broken tab
- Bucket Seats with Head Rest Any A Body Year
- Wheel studs for my Delmont 88
- 2026 Homecoming
- Fine Vibration at Higher Speeds
- Help finding Rear Quarter window mouldings
- Finding stuff in old cars
- Factory thermostat bolt length
- PCV grommet issue
- "s. M." ??????????
- Removed tic tach now car won’t start.
- What is this device?!
- Toronado GT Rear Bumpers
- timing set
- Oldsmobile ?
- 68-69 Fenders
- Oil viscosity/new cars
- Gravel Deflector
- Old poster of a black 1970 442 W-30 & Video
- 70 442 radiator numbers and codes questions
- Need a different ballast resistor?
- 70 442 starter part number
- Is there a source for a good 70 442/Cutlass assembly?
- The Story
- Another ‘71 W-30 on eBay, not mine
- Seeking 1942 Oldsmobile Owners – Let’s Build a Dedicated 1942 Community
- Carter fuel pump goes bad fast.
- 72 Convertible shoulder seat belts
- New feet
- Changing the gear oil in differential
- OAI Adapter Hose Lengths and Stripe Colors for '70
- 1968-72 Oldsmobile Cutlass Convertible Front 3-Point Seat Belts
- Jetaway vs TH400 in original 442s
- Adjustable Timing Set Question
- im back
- Additives in gasoline
- New Garage
- Thornton 455 Engine Mounts
- 394 CID Oil Sending Unit
- Aftermarket gauges
- 1971 Cutlass / 442 convertible top switch replacement
- Tire pressure
- Chuck, I have the parts you need
- New daily beater, new daily beater problems
- 1954 Oldsmobile F-88 Harley Earl saved it from destruction
- Need a favor ?
- HVAC Installer wanted central CT
- Tariffs on Edelbrock Aluminum heads US to Canada
- Sail emblem
- 1970 w30 rear end
- HOT ROD Mag 442
- Deep blue color help
- 4 core support
- '71-'72 442 4400 5400 ?
- The 463 Oldsmobile Omega Lives
- 1998 Eighty Eight LS
- 1970 442 front license plate bracket
- Brandon Reynolds - PM box is FULL!!
- 1972 Olds Delta 88
- Replacing front springs in my Vista
- Lansing Production
- Lock up kit advice 200-4r
- Radiator replacement question
- Head ID Numbers
- Rocket report ?
- 2026 Good Guys Muscle Car of the Year Finalist
- Powermaster XS 9510
- MCACN's 2025
- Non reclining seats or
- Wrong Center Link
- A Must Have Tool (Toy)
- Changed Motor Mounts & Oil Pan Gaskets
- W25 hood graffiti
- Hyundai now requires a dealer level scan tool for brake pad replacement
- Beautiful sedan delivery!
- Muscle Car and Corvette Nationals 2025, Nov 22nd and 23rd
- Tempest aluminum radiator
- Power seat, 4 way,
- What are these ID numbers ?
- "1970 F-85 Club Coupe Ralleye 350" for sale
- What is this 1972 Cutlass Supreme worth?
- The 1992 Aerotech used a 1995 Aurora V8?
- 66 442 trunk molding
- Amazon oil
- Oldsparts.com taken payment will not ship or refund - AVOID STEVE KENNY
- Wiper blades
- 442 with Christmas Tree on Roof
- 1965 442 Rochester 4-jet carb
- Interchangeable fenders
- Did Oldsmobile use this GM part?
- Everyday Performance Quadrajet rebuild book
- N95 Simulated Wire Wheel Cap - Wheel Color?
- Shipping for Hood
- PICTURE Request of 68-69 REMOTE ANTENNA Installed Help
- Correct 1970 Bumper Jack Hook question
- Saw this on Reddit
- 7 years and 1 day
- Carried the 2025 Ridler winner to SEMA.
- 1979 Door striker bushing
- Anybody live in or near Walla Wall WA ?
- 1970 442 w30 car
- Control arm check
- 1969 Trunk Rubber bumpers
- My 1983 Oldsmobile Delta 88 coupe, some questions
- GM Replacement Tank?
- interesting one-off '70-72 Cutlass tach
- 1980 Camaro seats into Gbody help
- 1970 White Interior Paint
- Alert !! not a Oldsmobile but !!
- Muncie 4 speed
- 1965 442 A Heads
- 1970 Window Felts
- Correct part #?
- 68 Factory Engine and Transmission Assembly Question
- Carburetor
- Carburetor question
- My Vista Cruiser on My Classic Car.
- Tony Angelo Buys Studebaker w/ Olds Power
- FYI - Legendary Auto Interiors has acquired American Cushion Industries, Inc. (ACI)
- Crazy money spent...
- New cowl seal; which one?
- Took my Kia to the dealership!
- 70 axle flang/backing plate bolt size?
- My 83 Delta 88 and my future options?
- Metal epoxy recommendations
- 455 camshaft
- Radiators
- Let’s talk oil filters and pressure bypass
- Pipes Oldsmobile down[ipes
- Need recommendations for Head Gaskets for stock Olds 350
- New garage door in the rain.... yeah
- Power seat transmission
- Plug wires
- Help identify the correct year
- Went for drive today
- Battery drain
- 62 Starfire convertible top
- 1970 W-30 auto A/C
- Vintage record shop bargain bin find
- 65 Starfire Questions
- 1970 Cutlass Supreme Radiator
- Might As Well ?
- Ultrasonic cleaner + evaporust = Kewl
- ThermoStat housing Cast Iron NOT Aluminum and Plugged
- Best for last I guess
- 1965 442
- 1970 Cutlass won't start
- Meanwhile...Somewhere in Georgia
- Hi everyone! Need some urgent help please!!!
- scan and 3-D print
- Jetfire turbo in NY
- Soft parts instrument cluster 67 Cutlass
- Roof Rail Weatherstrip
- What did I just do.
- RAD TAG Hoard
- Found an owners manual from a 1967 protecto plate is for FORD BELL
- 1969 -1972 Cutlass Hood Hinges: Slotted Holes to Fender
- Canadian Documents
- Starting Winter Maintenance
- Master Cylinder Rebuild Service Supply Chain Problem..??
- Looking for 425 parts
- Coil Springs
- Coming at you with a new look
- Driveshaft length. 72 with TH 400 and 8.5 rear end
- Shop work light for under your lift
- Fender Emblem Hole Placement
- Replatinng bumper shop
- 1966 Delta88 4 door hardtop outer window sweepers
- 1976 cutlass rear axle
- Bucket seats
- Upgraded the exhaust on my 65 Olds 98
- Boy how cars have changed...
- There are a lot of Mobil 1 Oils
- I cannot.
- First Brands Bankruptcy
- 455 and T400 Identification Help
- Gathering of Hurst Cars, Cartersville GA
- PROCAR Seats..?? Anyone use them.
- 1300 Cars, One Kind Man: The World’s Largest Collection Now For Sale | Barn Find Hunt
- Shifts and losses.
- 394 cam lift
- Florida BOP car show
- Endless summer cruise OCMD
- Oil change
- Thinking of piecing together a Tr-Carb set up for a 455 to go in my '80 Cutlass
- My 1967 Cutlass Supreme
- 70SX on BAT
- 72 1/4 panel extension seals
- Fred and the Fouranado on Jay Leno's Garage!
- Windshield wiper adjustment?
- water leak at door hinge area
- Thermostat housing weeping coolant
