Battery drain
Old Oct 26, 2025 | 01:04 PM
kevdog442's Avatar
Member
Battery drain
69 Cutlass, trying to figure out a battery drain issue. Drains overnight. With the battery negative disconnected I have full voltage from that post to the engine ground. I hooked up a test light and pulled each fuse. The light never went out. This has an external regulated alternator which is charging fine. Recently replaced the regulator but it didn’t fix the problem. Thinking maybe just old wiring?
Old Oct 26, 2025 | 01:16 PM
Disconnect the heavy red wire from the back of the alternator and test again. You may have a leaky diode.
Old Oct 26, 2025 | 01:18 PM
Unplug the harness on the alternator. There could be a bad (leaky) diode.
Old Oct 26, 2025 | 02:33 PM
illumined's Avatar
1978 Ninety Eight
There could also be a short, do all your electrical work fine?
Old Oct 26, 2025 | 02:40 PM
kevdog442's Avatar
Member
The test light goes out when I unhook either one of the connections at the alternator
Old Oct 26, 2025 | 02:41 PM
kevdog442's Avatar
Member
yes
Old Oct 26, 2025 | 02:56 PM
Sounds like you found the problem. If you want 100% confirmation, you can bring the alternator to an auto parts store and have it tested.
Old Oct 26, 2025 | 03:48 PM
kevdog442's Avatar
Member
Alternator tested fine, diode ok. Gonna go through the wiring connections
Old Oct 26, 2025 | 04:22 PM
Sugar Bear's Avatar
How/wherer was the alternator tested?
Old Oct 26, 2025 | 04:42 PM
kevdog442's Avatar
Member
I had the car running with lights on, disconnected the positive. Stays running. For the diode I went to the school of YouTube and watched a few videos. Tested with a multimeter.
drjimz
Aug 20, 2024 03:06 PM
mrtoronadoman
Jul 18, 2023 03:16 AM
J1978
Aug 25, 2021 06:29 PM
riskyb
Oct 13, 2020 10:19 AM
1976CSB455
Apr 30, 2020 10:00 PM
