Remote oil filter
Old Jan 14, 2026 | 05:31 PM
dennis_30281's Avatar
Remote oil filter
Anyone ever install a remote oil filter on their 394
Old Jan 15, 2026 | 04:51 AM
I only ever used standard cartridge filters on my 64 98 with a 394. Back in the day when Fram filters didn't suck.
Why do you want to run a remote filter?
Old Jan 15, 2026 | 08:03 AM
coldwar's Avatar
One of mine has a remote set up. It's a Eelco bolt on adapter that replaces the spin-on aluminum unit. Has two large female bungs. Then out to the commonly seen dual spin on filter housing. Has worked fine in like forever. You see these pop up on ebay but I haven't looked in a while. The Hildebrandt adapter is triangular likewise with fittings. You could make one using a gasket as a template.
Offenhauser still offers them for 303-371 - and 394 style in both bypass and block off:
https://offydirect.com/product/offen...-bypass-plate/
Offenhauser 5317 1959-1963 Oldsmobile Oil bypass plate
Old Jan 15, 2026 | 05:35 PM
Thank you, will check
TONY at Ross Racing Engines makes the plate, but is out of stock.
dbater
Jun 28, 2022 01:32 PM
Bigmikey65
Dec 8, 2021 09:13 PM
atle
Dec 26, 2014 06:06 AM
72 Olds Project
Aug 14, 2011 06:43 PM
