Radiator replacement question
Old Nov 24, 2025 | 07:28 AM
sshriber's Avatar
Good morning. I have a 1970 SX. I am needing to replace the radiator. I notice that many of the replacements have a 1.5 outlet in the bottom position. I know the hose is 1.75. I have seen people use a spacer to make them 1.75. My question is, does the smaller diameter opening effect cooling? Thank you
Old Nov 24, 2025 | 07:43 AM
I had always wondered about that, too. The smaller size is for the 1971-newer applications. The 1968-1970 used the larger size. But as the later engines cooling was sufficient, I would guess the smaller hose sizes wasn’t an issue.
Old Nov 24, 2025 | 09:27 AM
VC455's Avatar
Barely Registered
Kenneth's observation is correct; however, many people use a rubber adaptor bushing to allow the larger, existing hose to fit the smaller outlet.
Butler Performance sells one: https://www.butlerbuiltperformance.c...p/all30240.htm
Others are currently on eBay.
If you don't use the adapter, you may have trouble at the water pump end trying to use a smaller hose.
Old Nov 24, 2025 | 10:16 AM
There are a few ways to do this, Gates, Jegs, Allstar... to name a few that slip over the radiator port. This is what I have on mine and it's been good since 2009.
Amazon.com: JEGS Radiator Hose Reducer | Adapts From 1.75” ID To 1.5” ID | Black Rubber | 1.875” Length | 1 Per Package : Automotive Amazon.com: JEGS Radiator Hose Reducer | Adapts From 1.75” ID To 1.5” ID | Black Rubber | 1.875” Length | 1 Per Package : Automotive
Sponsored Ad - JEGS Radiator Hose Reducer | Adapts From 1.75” ID To 1.5” ID | Black Rubber | 1.875” Length | 1 Per Package
You can also go with a coupler hose and a 1.75 hose barb coupling
Auto Dynasty 1.75 inches To 2 inches Straight Turbo/Intercooler/Intake Piping Coupler Reducer Silicone Hose (Black)
YSIL 1-3/4
or a 1.75 to 1.5 hose barb reducer and a straight piece of 1.5 hose.
JoyTube 1 Pcs 1-1/2 to 1-3/4 Inch Radiator Hose Barb Adapter, Coupler Splice Mend Coolant Intercooler Exchanger Heater Rep...
Sponsored Ad - XAJINGSU 4-Ply Reinforced Straight Silicone Hose Coupler 1.75 ID (45mm), Length 3(76mm) High Temp Leak Pr...
Old Nov 24, 2025 | 06:14 PM
sshriber's Avatar
Thank you guys. I appreciate your input
Old Nov 25, 2025 | 04:42 AM
jensenracing77's Avatar
Does your car have the original radiator in it now? If so, is it a 4 core? If it is the original 4 core it is very much worth having it re-cored. If it is a 4 core, it is likely a very valuable radiator and I would keep it in the car with the new core. If you go that route be sure they reuse the top and bottom rail instead of the replacement rails that can come on a new core.
Old Nov 25, 2025 | 06:48 AM
What Eric said. If you have the correct original radiator, have it recored. As for the aftermarket replacements, vendors try to save money by consolidating parts. Since the 1.5" outlet works on early cars with the bushing, that's what vendors stock - one part number instead of two. The smaller diameter isn't a problem - that outlet isn't the smallest restriction in the system as far as flow is concerned. By the way, I also have seen aftermarket radiators where the outlet port is stepped so it can accommodate both hose diameters.
Old Nov 25, 2025 | 07:15 AM
Run to Rund's Avatar
By the way, if you have the stepped outlet port (the upper one) and are using the bigger part, I recommend cutting off the smaller end. Otherwise the pressure can blow off the hose, even if the clamp is very tight-- spraying hot coolant everywhere--ask me how I know!
tkcutlass
May 30, 2022 01:36 PM
harpelt
Apr 3, 2016 04:01 AM
jdclemons
Aug 27, 2014 12:48 PM
Last98
Dec 26, 2013 06:21 PM
Finn5033
Dec 2, 2012 09:57 AM
