Choke stove Tube
Which tube do you need?
There are 3:
the U shaped heater that goes into the exhaust passage in the intake manifold.
the tube that goes from the U heater to the carburetor choke housing
the tube that goes from the U heater to the air inlet on the top rear of the carburetor.
All are available from multiple Oldsmobile vendors.
There are 3:
These are available from Dorman at your local auto parts store if you aren't doing a concours restoration.
https://www.summitracing.com/parts/rnb-76850
If you cant find one we have made them from a 3/16" OR 1/4 "brake line & just flare the end going into the choke spring housing with the flare nut.
There are 3:
There are 3:
