Choke stove Tube
Old Jan 20, 2026 | 02:40 PM
Tegra1027's Avatar
Choke stove Tube
Does anyone know where I can buy a choke stove tube for a 455? I found one on ebay but its listed for a 350. Thank you.
Old Jan 20, 2026 | 03:43 PM
Jungle Cat's Avatar
Fusick I believe sells them
Old Jan 20, 2026 | 03:55 PM
Which tube do you need?
There are 3:
the U shaped heater that goes into the exhaust passage in the intake manifold.
the tube that goes from the U heater to the carburetor choke housing
the tube that goes from the U heater to the air inlet on the top rear of the carburetor.
All are available from multiple Oldsmobile vendors.
Old Jan 21, 2026 | 04:23 AM
These are available from Dorman at your local auto parts store if you aren't doing a concours restoration.
https://www.summitracing.com/parts/rnb-76850
Old Jan 21, 2026 | 04:38 AM
zl1 camaro's Avatar
If you cant find one we have made them from a 3/16" OR 1/4 "brake line & just flare the end going into the choke spring housing with the flare nut.
Old Jan 21, 2026 | 07:04 AM
Tegra1027's Avatar
Not a bad idea. Thank you.
Old Jan 21, 2026 | 07:06 AM
Tegra1027's Avatar
There are 3:
I didn't realize there was a third. lets assume all three then... Do you know if the parts for a 350 will work with a 455? I only see them for a 350.
Old Jan 21, 2026 | 09:54 AM
Jungle Cat's Avatar
455 is there. Has to be
Old Jan 21, 2026 | 10:21 AM
Jungle Cat's Avatar
Easy to find in Fusick caralog
Old Jan 21, 2026 | 11:59 AM
Here's a one stop shopping source:
https://www.thepartsplaceinc.com/par...ke+heater+tube
Old Jan 21, 2026 | 01:51 PM
I replaced mine from ILT
https://www.inlinetube.com/collections/all?q=choke
Old Jan 22, 2026 | 08:35 AM
newmexguy's Avatar
may still have some of those pieces, in my '455 miscellaneous pile. dave s.
72 Post
Jun 29, 2023 05:52 PM
tdhill01
Nov 28, 2021 05:03 PM
stephenca118
Mar 16, 2017 06:24 AM
Bill D
Dec 12, 2016 08:25 PM
perksolds
Aug 24, 2006 07:34 PM
