Factory thermostat bolt length
Old Dec 27, 2025 | 01:03 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Just curious what the factory bolt length was.
Old Dec 27, 2025 | 10:57 PM
Were all the thermostat housing flanges the same thickness? I thought the original aluminum(?) one on my 70 was thinner than the iron replacement, but it’s been 40 years so maybe that memory is inaccurate.
My thought is the bolt length may vary depending upon the housing.
Old Dec 28, 2025 | 05:52 AM
VC455's Avatar
Barely Registered
In 1970 they were 5/16-18 x 7/8" per page 6-17 in the Assembly Manual.
Old Dec 28, 2025 | 02:52 PM
Thanks, I was going to look through it, didn't think it would be in there. I picked up the Oldsmobile and an AMC Dorman replacement housing. The AMC is a bit taller and needs the holes tweaked slightly for the Olds pattern. Both are aluminum and the AMC has a threaded port, perfect for my cooling fan sensor. See which one works better. Now I know what size bolts I need.
Old Dec 28, 2025 | 08:22 PM
66SportCoupe's Avatar
If you're not worried about original look use studs in the thermostat housing.
Old Dec 29, 2025 | 05:30 AM
Not a bad idea, will look up some studs.
v8al
Feb 3, 2023 03:13 AM
Kyle's77cutlass
Drivetrain/Differentials
15
Feb 24, 2020 05:44 PM
dhwhite43
Sep 1, 2018 06:38 PM
dman0712
Mar 16, 2010 07:40 PM
mcutlass1969
Mar 6, 2008 10:24 AM
