Looking for 425 parts
Im looking to get a 425 started. Ill need the accessories or do you know if anything will interchange like the starter, distributor, what aftermarket carb could I use, ill post pictures of my engine soon
For the most part, any external part that fits a 455 will also fit a 425. That includes intake, exhaust, distributor, carb, water pump, timing chain, oil pump and pan, etc. Even the heads interchange. Differences are the flywheel/flexplate (due to the different crank flange bolt pattern), the cam (if the block is one with a 45 deg lifter bank angle), and the rotating assembly due to the shorter stroke, longer rods, and different piston compression height. Also some 425s have 0.921" lifters vs 0.842" diameter.
Why use an aftermarket carb ? Get a stock carb and you won't need to adapt or cobble things up. Carb linkage, transmission kick down, fuel line, carb jetting are some things you would need to have working right. You can always swap to an aftermarket carb later when things are running right.
