Looking for 425 parts
Old Oct 17, 2025 | 11:59 PM
RocketRonnie's Avatar
Im looking to get a 425 started. Ill need the accessories or do you know if anything will interchange like the starter, distributor, what aftermarket carb could I use, ill post pictures of my engine soon
Old Oct 18, 2025 | 05:27 AM
Andy's Avatar
You can use a edelbrock carb, fairly cheap and the work good. Distributor from any 65-57 olds maybe others too. Starters are cheap, I have a distributor and a starter if you need one.
Old Oct 18, 2025 | 06:26 AM
For the most part, any external part that fits a 455 will also fit a 425. That includes intake, exhaust, distributor, carb, water pump, timing chain, oil pump and pan, etc. Even the heads interchange. Differences are the flywheel/flexplate (due to the different crank flange bolt pattern), the cam (if the block is one with a 45 deg lifter bank angle), and the rotating assembly due to the shorter stroke, longer rods, and different piston compression height. Also some 425s have 0.921" lifters vs 0.842" diameter.
Old Oct 18, 2025 | 09:16 AM
OLDSter Ralph's Avatar
Why use an aftermarket carb ? Get a stock carb and you won't need to adapt or cobble things up. Carb linkage, transmission kick down, fuel line, carb jetting are some things you would need to have working right. You can always swap to an aftermarket carb later when things are running right.
Old Oct 18, 2025 | 09:56 AM
Andy's Avatar
because it doesn’t sound like he has a carb or distributor ..
Old Oct 19, 2025 | 06:09 PM
DR_DAN's Avatar
I have an MSD billet 8566 distributor
MSD 6A,6AL, digital 6AL, brawler 750 vacuum less than 400 miles on it, etc. if this is anything you might want pm me
Jetmek
Feb 20, 2024 05:15 AM
Andy W
Aug 28, 2022 10:49 AM
Tgbunch
Aug 22, 2022 09:56 PM
aggrorider1
Apr 4, 2022 06:23 AM
montvaleplace
Feb 7, 2016 10:01 AM
