Oil change
Oil change
How often does everyone change the oil in their classic oldsmobile?? I do mine once a year because I only put on a 1,000 miles a year. Should I wait longer or is that good?
With mileage like that, your approach is totally reasonable. I do my 455’s about 2x a year but put 2 or 3 thousand miles on my cars per year, I think.
Basically you want the engine oil to be a nice honey color (not black) when you take the car out for a run and you want to be sure it’s full (not needing) oil. Before you fire up the car, check the level & color cold. If it’s not been run for a few days, all the engine oil will be in the pan so you get the most accurate level measurement possible. Keep a quart of your preferred oil in the trunk so you can add at will.
I use blue tape on my radiator with scrawled notes about the last oil change date, oil weight and my Lucas additive. I also scrawl the oil change date on the filter with a sharpie. That way next time I wonder about it, I know what I did 6 or 9 months ago. There are more elegant solutions, like a logbook, but scrawling on parts works for me.
I’m in the camp of “an oil change is cheap insurance”. I do my Audi’s at 5,000 miles with synthetic, although Audi recommends oil changes every 10k miles. But then my 122k mile 9 year old V6 runs like a top and a lot of people are turning the 2016’s in because the burn oil. VW-AG (aka Audi) is in the business of selling cars. I deeply suspect their maintenance recommendations support more sales than max value to customers.
Carry on and have fun with your car.
Cheers,
Chris
Cheers,
Chris
I'm in the limited-mileage camp too, so every fall before I put it away. Actually, I'm thinking of giving it a miss this year because between extensive summer travel and fuel system woes, last fall's oil change only has about 25 miles on it.
I agree on the spring oil changes, once a year no matter the mileage, same for the boat, every spring, oil and filter and gear oil in it's drive. Honestly the amount of oil changes on the fresh engine was a lot and dropped the gear oil in the rebuilt Olds 12 bolt rear and may do it again this Winter.
Even though I had firsthand access to good data, I STILL routinely change all of my oil approximately every 3k miles. The 'toys' get an oil change once a year due to limited mileage and living pampered lives.
