Oil change frequency
Once a year changes before storage would have cleaner oil without combustion by-products sitting in the engine and the engine starts on fresh oil. Old oil sitting in the oil pan would cause corrosion/pitting to the interior of the oil pan on marine engines stored for the winter.
My $0.02...
My $0.02...
Once a year on the cruisers . If I'm running a racing series like I did last year half way through I will change oil so every 6 races for cheap insurance on the street strip set up
If you're driving the car frequently, it's better to go by mileage. Most people here would probably go with a maximum of 3K between changes. Also depends on if you're using synthetic or dinosaur juice.
Next time you do an oil change, consider sending a sample to an oil analysis company, the type used by owners of commercial vehicles.
This will tell you if there are corrosive elements in the oil. And for another $5 they will analyze to inform you how much life is left in the oil.
When I did this for my DD, I found that I could comfortably go 12,000 mi between changes--even when that constituted two years of service (although my oil tell-tale message comes up every 3,000 miles or so). However, I rarely drive that car on short trips, sump capacity is 8 quarts, and I use synthetic oil as the manufacturer calls for.
I try not let my daily driver 17 Dodge Challenger GT go below 40 percent, which is usually 10,000 km with combined driving. Towing or more City driving lowers it, quite a bit. I use full premium synthetic 5W20, 0W20 in Winter. My worthless Dakota gets a spring conventional and winter synthetic oil change to help it start in -40. I get the fresh oil idea but up here it sits 6 months, not so fresh by then. The Olds is usually once a year, thr new motor will get many short, break in oil changes. I do the start up and make sure everything is running properly then once warm, then immediately drain and fresh oil and filter. I also leave non ethanol Premium 91 with STP additive/stabilizer over the Winter, usually top it up with a Jerry can of the same before start up. I am going to pay close attention to my outboard motor oil this spring for signs of moisture. I fog and cover it, do the same check over and immediate oil change once the cylinders completely clear out running fresh ethanol free Premium 91.
Tedd Thompson
June 14th, 2012 07:28 PM
