- W31 350 engine
- Engine repair in GA
- Question Rochester 2 JET carburetor
- Emergency brake hardware inquiry
- Changing Light Switch in Dash
- Wide Band Tuning Question
- E body platforms
- Base Timing for 1965 442
- 1965 442 Distributor help needed
- Battery for Cutlass S 350 4V
- Starting peculiarities Rochester quadrajet
- 1970 New Front Light Harness and Rear Lights Won't Work
- N93 aluminum or magnesium disc
- EGR valve plate need helo finding
- Carburetor Float Height
- Trim Tag Decode Help
- machine shop
- 1992 98 window trim question
- Replacement Air Filter
- 1970 Cutlass Supreme Convertible Top Issues - Video
- Proper bolt for alternator bracket
- 64 Ninety Eight rear suspension bushings
- 1970 442 power window install questions
- oil leak 455 back passenger side
- Manual transmission clutch fork spring installation
- Radiator question- 1964 Dynamic
- Ignition lock, rack sector gear, steering column problems
- Oil filters.
- Are 68/69 front and rear bumper brackets the same?
- 1967 Cutlass Supreme
- Previous owner used wrong alt bracket?
- 1962 Oldsmobile Dynamic 88 gravel guard splash guard valence
- Heater Core - Oldsmobile Super 88 1964
- AirRide suspension for the 1966 - 98 holiday coupe
- 1970 Tail Light Housing Wires?
- Brake Component Detail Paint
- Timing chain
- Glove box lock cylinder dash
- 71 cutlass chrome mirrors
- Cracking nylon coated timing gear
- Idle problem on my 66 Toronado after backfire, and pinging under load
- 8.70s with nitrous
- 1969 s cutlass seperating the dash?
- What fuel pump
- Electrical terminals
- Mechanical or electrical gauges??
- Cam shaft question
- Engine painting details (for judging)
- various parts
- 1968 cutlass/ 442 fender eyebrow trim replacement
- 1969 Cutlass 350 Coloring and Factory Engine details
- Sourcing of AC ducts
- Rotten water jacket
- Cleaning factory valve cover baffle
- CCC Quadrajet throttle plate gasket
- Where on a 303 engine is an oil passage fitting
- Fuel line fittings for a 1953 Super 88
- Blower motor runs all the time -1969 442
- Motor height issue
- ‘72 Grilles
- Rochester 7042251
- Goodyear Eagle ST Tires
- Interior lamp module from late model GM truck
- 1962 Olds 98 Front Lower Suspension Arm
- Help with my 1965 Olds F85 1 barrel carb leaking
- 1970 442 Glass
- Battery cable questions?
- 85 cutlass rear main seal 3.8
- Help with `84 Cutlass
- Vacuum Control Diagram
- Pulleys/water pump for vintage air
- Quick question about my Olds
- Quarter window trim
- 69 ram air scoops
- 1966 442 Trunk molding
- Pcv question..
- Convertible Top Boot Installation
- Radiator
- Head gasket question
- Tranny line 'kink'
- 1972 Convertible Switch Relocation Options
- Fuel filter 1966 Oldsmobile Delta 88 425 ci
- Wheel nuts
- How to Calibrate a 67 Rally Pac Tachometer?
- Lug nuts
- 66' Fisher Body Manual help
- Valve stem clearance
- 425 valve adjustment
- Ignition Points Issue
- Best oil for 1957 371 engine
- Carburetors
- Radiators
- Correct trunk bumper for '72 Supreme coupe?
- 1969 Rally Pack gauge issue
- T-3 cut off date
- Quadrajet ID
- Early TH400 code OD transmissions
- 1983 Cutlass 2 dr Driver Power Seat Issue
- Parts Place Wheel Liner Fitment
- 69 Cutlass cruise control question.
- Parts Help Needed
- Solid state module, weird screw, help!
- Low vacuum or not.
- Camshaft Identification
- 1965 Oldsmobile Starfire versus 1965 dynamic 88
- Electric priming pump
- Thermostat housing bolts for Holley Street Dominator
- Brake hub cap
- 1972 Tic toc tach
- What the best way to sell a 1989 olds 98
- Newbie carb question
- Tm 425 vaccum modulator help please
- Side Tank Size? OR WTB "ED" code 4-row Radiator
- 1972 442 paint
- Smog pump vacuum routing needed
- Weight of car lifting front wheels.
- Adding gauges to '68-70 Toronado Instrument panel.
- Rear differential
- 72 seat belt buzzer
- Oil dipstick 1971 Small Block 350
- PCV Valve 67 330 Quadrajet
- A/C Delete Blower Resistor
- No start 98
- Exhaust system
- A/C hose assembly
- Harmonic bud balancer removal/install
- 1960's Olds Front Disc Brake Conversion Kit
- Expansion Valve Capillary Tube
- 1964 Cutlass Cowl Tag
- Qjets - Been hitting the books!
- Tail light gaskets
- 1964 Cutlass valve cover "PCV"
- New wiring harness
- Fuel pump to carb fuel line routing 69 442
- Help with skip Please
- 83 Olds 307 - EGR solenoid
- 64 Olds. V8 Fuel Pump Replacement
- Garage find 1970 442 questions
- Let’s discuss U joints.
- Where to get this oil filler cap?
- Rochester fuel inlet gasket
- Rochester 4gc issues
- Olds 98 steering column turn signal questions
- vintage air Gen 5 install
- no gas flow 1968 cutlass mechanical pump
- Anyone know what this is? 84 lesabre 307 olds
- Rochester Quadra jet Rebuilt Kit
- New to me 68 442 TC
- Reverse neutral switch
- Touch up paint for 1957 Oldsmobile 88
- Olds 98 steering column questions
- Trunk latch
- 1957 Oldsmobile 88 Heat and Ventilation System
- HEI update
- 260 olds water pump
- 84 Lesabre wiper issue
- 4 speed console questions- easy ones..
- steering wheel not seating
- Headers
- Good source for 1968 Cutlass/ 442 informational material?
- Inner Fender Flaps
- Ignition coil external condensor.
- Good Source for Quad jet rebuild kits
- rebuild instrument mounting post 1967 442
- 1971 montecarlo
- Aftermarket / repro chrome bumpers experience ?
- Dropping A/C ducting in 67 442
- Cold Case Radiator Issue
- Hydramatic transmission rebuild
- 1957 Oldsmobile 88 Thermostat Housing
- Spindle casting numbers
- Brake Booster/Dies at Stop
- AC not working 1971 442
- Dakota digital or similar instruments
- Vacuum system question
- Just joined this forum - some basic questions
- Adjusting Side Glass - 1970 442 Convertible
- Performance camshaft part numbers
- Motor swap
- 1969 Cutlass S vaccum trunk release diagram
- Heater control cable info needed...
- 67 gas tank cap
- 1964 Cutlass Quarter Panel Trim Clips
- Fitech EFI Return Line
- Engine hesitation while turning right
- Radiator hose options
- 260 / 350 Exhaust Manifolds
- Engine clearance specs? [330]
- 84 Cutlass v6 hard start when cold
- 307 vs 3.8L mid 80’s full-size cars
- Quadrajet 7040253
- Steering column Delta 88 from 67
- Speedometer Cable
- Dash Appliqués
- Lower grille ties. Do they actually exist?
- Edelbrock 3711 intake 1906 carb
- 68 cutlass valve covers
- 1970 A-Body Convertible Rear Speaker
- 1968 instrument panel questions
- Quadrajet carb 17056259 - 800cfm Manual Trans?
- Speedometer wheel drive
- Black VS Red?
- 72 Supreme Convertible ac firewall to non ac firewall
- Engine Cradle Location
- Looking to figure out my olds.
- What is this
- Accel ignition points question
- 1964 Olds 98 4dr sedan - rear door seal
- radiator / old school new vs. aluminum
- Washer Pump Installation Instructions
- 84 88 AC orifice
- Rally Gauges rebuilders
- 69 Open Faced Alternator Front/Rear Bearing Questions
- Rear differential question
- Production Code "2" sheet - what does it mean?
- Oldsmobile body mount volor paint code
- 64 Cutlass nut,bolt,and faster Identification
- OAI Hood latches
- 58 Jetaway
- Plating questions
- Convert 62 Starfire from generator to alternator
- 1970 clutch pedal linkage bushing
- Valve Cover Spacers 22521731
- Install Height on 1956 #10 Heads
- Anyone in readerland have part numbers?
- 70 Vin info needed
- Metering jet size
- bumper re chrome
- How do I make my oil tube fit???
- Fan spacer number..
- 1970 Engine assembly Manual
- Delco Thermostat part number 1970 442
- Need help PLS!! Identifying fuel lines
- Manifold Studs
- B&M Quick Silver automatic shifter
- Factory '71 Cutlass/442 convertible rear speaker?
- Torque converter dust cover
- Block Deck Height of '49 - '64 Engines
- Done business with these guys?
- Replacing Body Bushing problems
- VIN derivative
- Having trouble taking the Throttle cable off my olds 307
- 77 Toronado Tempmatic question
- Need Help Diagnosing
- Heater delete hose routing 67 and earlier.
- 64 Cutlass remote trunk release
- Wheel well trim
- Heater Hose Valve Shutoff?
- 1970 442 Water Pump
- Road Noise 75 Hurst Olds /Cutlass Supreme
