67 gas tank cap
Old Apr 15, 2025 | 09:58 AM
brianbeez67's Avatar
67 gas tank cap
so the story goes
Brand new gas tank for my 67 cutlass supreme. Lost both of my old caps. So I went to local parts store and bought the above cap.
unfortunately it will not go on. I can’t get the two (teeth if you will) far enuff into the tank neck seating area for me to twist it on.
Any thoughts?
Old Apr 15, 2025 | 10:14 AM
Oldsmaniac's Avatar
Fusick sells them.
Old Apr 15, 2025 | 12:01 PM
I would venture to guess that since you installed a brand new tank, that the filler opening of the neck on the new tank isn't an exact match to an original '67, thus no cap advertised to fit a '67 will work. I'd contact the manufacturer of the new tank and ask them if they sell a cap that fits, or if they can point you to a manufacturer that does.
Old Apr 15, 2025 | 12:30 PM
Tri-Carb's Avatar
Lube the rubber gasket. I did this for a 66. Then, using a glove, work in on and off a few times. If need be, you can, file, sand and lube the ears on the cap.
The Fusick cap will fit better but at 3-4 times the cost of the aftermarket unit.
Old Apr 17, 2025 | 08:34 AM
Taz54904's Avatar
As funny/odd as this may sound, check the inside lip of your rear bumper for one. Last year when I was installing a vent line to my tank, I found two old gas caps resting on that lip. I had to laugh thinking of the previous owner trying to remember where the cap went when they were filling up the car. LOL
Old Apr 17, 2025 | 01:16 PM
Will throw a wide net. Will contact the company I bought it from and maybe try the grease method too
Old Apr 19, 2025 | 12:32 PM
The company was no help AT All, I used the suggestion of lube/ silicone on the gasket and some elbow grease.
Bamm, I’m happy now
It fits.
Old Apr 19, 2025 | 12:40 PM
Bamm, I’m happy now
It fits.
Good deal, I'm glad the simplest solution worked for you! 👍
JVCCutlass
Jun 22, 2024 02:15 AM
Cosmic Charlie
Feb 4, 2020 05:50 AM
oldcutlass
Dec 30, 2013 08:49 PM
Rob delta
Dec 15, 2012 01:38 PM
VikingBlue
Sep 21, 2010 05:28 AM
