Oil filters.
Old Apr 9, 2026 | 09:54 AM
Neuby7297's Avatar
Oil filters.
What type of oil filter should I use? I have a 72 Cutlass with a 350 4bbl. Air Conditioning. I use Lucas 10W-30 HotRod Classic with zinc. AC Delco no longer makes the filter. What could I use as a replacement? Thank you.
Old Apr 9, 2026 | 09:58 AM
Wix 51258
Old Apr 9, 2026 | 10:02 AM
Wix 51049 is larger and has more filter area. Unless you have headers that restrict fitment, the longer 51049 will fit just fine. All three of these are for Olds motors. The smallest 51045 is for the 1980s 307s.
Old Apr 9, 2026 | 10:35 AM
fleming442's Avatar
That pretty well covers it. The 51049 will fit with Hooker Super Comps, but ARH require the 51258.
Old Apr 9, 2026 | 12:49 PM
My 350 has Heddman headers and the 51049 fits.
Old Apr 9, 2026 | 01:23 PM
redoldsman's Avatar
Proud Viet Nam Veteran
A number of years ago I saw a Wix and a Fram filter cut open in a display on a parts counter. I have never used anything but Wix since them.
Old Apr 9, 2026 | 02:33 PM
^^^ Exactly this!
Old Apr 11, 2026 | 12:35 PM
And just to clarify, NAPA Gold #1049 no longer = Wix #51049, correct?
Old Apr 11, 2026 | 01:11 PM
Hmmm. I just looked up a NAPA Gold 1049 filter, then clicked on the warranty link, and it brought up this page showing Parker Filtration Group as the manufacturer.
https://assets.genpt.com/pdf/id/485118531
The WIX filter site has a Legal tab that indicates MANN+HUMMEL is the manufacturer.
https://www.wixfilters.com/en-ap/cat...achInformation.
The internet says MANN+HUMMEL owns Wix.
Old Apr 11, 2026 | 02:23 PM
I just used a 51049 this morning and I have full length Hedman headers on my 71 98. Here's a picture of me returning to the barn.
Old Apr 12, 2026 | 06:46 AM
Correct, unfortunately this changed a couple of years ago.
Old Apr 13, 2026 | 05:34 AM
BillK's Avatar
Personally I would use the AC Delco PF61E which is a smaller filter but will work just fine on a stock engine. It is what they show for the later 350's. If you want to use Wix then the 51045 should be the same.
Old Apr 13, 2026 | 05:38 AM
Yes, 51045 is the small diameter Wix filter for Olds. It's used on the 307s. I was able to fit a 51258 on a 307 in a pinch once when I realized too late that I didn't have any of the small ones on the shelf. The only problem is that you have to push the trans cooler lines out of the way.
dbater
Jun 28, 2022 01:32 PM
Bigmikey65
Dec 8, 2021 09:13 PM
pdsap
Apr 7, 2020 12:16 PM
bulldog
Mar 6, 2013 03:20 PM
Brizio
Mar 7, 2009 10:59 AM
