View Full Version : General Questions
Pages :
11]
16
17
18
19
20
21
- Help to identify '69 vs. 70 442 hood
- another question..BB head on small block
- Door glass
- Firewall insulation
- ECM/PCM Repairs
- '93 Cutlass Stalling issues solved
- Fig. 6-83-Front Door Window Removal and Adjustment
- carb adjustment Q; 1970 442, reilt 455 & quadrajet
- which Steering Coupling Assembly to buy
- roller cam 307
- Hot or Not?
- 1972 Model Year MSRP Breakdown
- Definition of lubricants in 66 Manual
- Scrap yard between indiana/ohio
- Transmission lines 700R4
- Rocker arm sets.
- fresh 455 overheating on the highway
- 77 cutlass - how to remove seatbelt from floor?
- Not charging the Battery
- 1957 Oldsmobile Fiesta Hood..
- Convertible top motor
- Check Engine Light
- overheating 1974 OLDSMOBILE CUTLASS SUPREME 5.7L
- 3 Row Radiator In A Non A/C Application - Is This Right?
- Replacement of '76 Salon Dimmer Switch + Wiring Update
- Convertible top tear repair
- Fuel Octane/Additives
- Coil Condenser Question
- Glove Box Lock Question
- All Headlights Go Out when High Beams Are Turned On
- What's is called?
- 1972 Cutlass Suspension
- 1966 2-door/4-door hood interchange
- Water pump bolt vs stud - factory PIM vs reality
- Odometer swapping
- Exhaust manifold question
- Heated choke question
- Epoxy a solution for stripped Q-jet fuel filter recepticle threads?
- 1955 Olds Radiator Rubber Strip on top bracket above radiator
- 71 442 back glass install
- Vin decode
- Valve stems used on 1972 Cutlass 442
- What long tube headers fit well in a 1969 Cutlass with a 455?
- Rarest 71 Olds Cylinder Head?
- 1978 Regency VECI info
- 1976 Olds Dash Panel sourcing
- Qjet rebuild kit question
- What's this?
- Can't take the heat!
- 63-64 windshield interchange?
- Advice on driving 1300 miles, running hot
- oldsmobile 455 engine id numbers/letters location
- Points, Dwell, Timing, etc.
- 1965 Delta Front Wheel Hub Differences
- 1965 442 engine specs
- Weird dents in front bumper
- 1969 Cutlass 455 alternator belt
- Vin tag placement
- 1977 Cutlass Assembly Manual???
- 75 crossover pipe
- Paging TK-65
- Driver side kick panel removal 1970 Cutlass
- Can I Disable Flow-Through Ventilation?
- Pwr antenna wire & remote trunk opener vacuum runs '69 a-body
- European VIN Tag?
- 1969 Cutlass S 455 with headers exhaust system question
- quadrajet Qjet port identification and whats this ?
- need vacume hose diagram...
- 1969 Cutlass and 455 muffler preferences
- Rag joint ground wire
- the '69 Cutlass tail light lens
- quarter window problem
- 70 442 Vinyl Roof Chrome Trim Help ¿?
- fuel line 68 cutlass/ 442
- Headers question
- Timing chain replacement questions
- 65 442 motor rebuild
- New exhaust system
- Never Seen This Before!
- numbskull explodes mufflers in driveway
- 1 piece oil pan gasket 455
- 1955 98 Anti Sway Bars
- 69 numbers matching 442
- Exhaust system question
- Viscus Fan question
- 56'Olds 4317 fuel pump
- engine swap issue, 371 & 394
- Rear main seal
- 1964 f85 v6 4 speed
- Hot air tube and shroud assembly
- 1958 98 hardtop mouldings fit?
- Torque Specs for 1969 455
- who has done carb recoloring using Chromic Acid
- Correct power steering cap
- Trunk Lock Cover Restoration
- A Body Power window wire routing
- Charlotte,NC -area Shop recommendations
- 1979 Olds 350 Smog advice wanted
- backfiring issue
- 68 Weatherstrip
- Battery Disconnect Question
- 455 valve issues
- Mechanic in NJ
- Coil Springs - Is This Right?
- 70 442 Air Conditioning System Installation
- 1970 fan shroud
- 69/70 Interchangeable parts
- carburetor linkage
- Whaaaat?
- Scratched glass repair
- 15" tire size
- Original application?
- Gas tank venting -'67 Olds C.S.
- Oldsmobile headers
- Stuck air horn screws
- What are Carb Specs for 1979 Olds 350 R engine?
- Power antenna
- 455 Pinging
- Driveshaft Stripe Oddity
- Bent push rod
- Reconditioning thermostat housing
- Ocassional misfire
- Hood release retaining clip
- AC Service ports
- 1969 olds 442 mutiplexer radio
- flutter.
- What to use on 455 exhaust m/fold
- Changing hood hinge and spring
- Want to put an sbo in a Camaro
- Intake manifold turkey tray sealant
- Are dash pads interchangeable 68 and 69 Cutlass?
- Trouble starting after seting 5 hours or more
- Spark plugs 350
- Valve stem seals
- Car Shipping Order
- 68 Hurst Olds Battery Question
- Does anyone here have a copy of Section 8, Page 102 in the 1970 manual?
- Timing chain
- Original 1968
- Identification
- Will a 68 GTO steering column fit my 67 Cutlass
- Numbers Matching, what does it mean?
- heater core replacement advise needed
- 700r4 transmission
- Converter Drain Plug on '76 Cutlass?
- 1965 Delta 88 Factory AC Question
- Intake manifold
- Difference in Coils: U505 and E552C
- 68 442 Heater/AC hose routing/clips
- Number steamed on rear crossmember
- Intake Fuel Port Sealing Ideas Wanted
- 1965 4sp. Hump
- Ignition Coil Resistance Specs
- 3x2 choke pull off
- Drilling crank for pilot bushing
- Electrical Issue Solved
- 455 crankshaft bobweight
- Warped carb Air Horn
- 1969 Cutlass odometer
- window regulators
- Waterpump rebuild
- oil pressure sender
- Soft Top will not fully retract
- 72 Cutlass Power Door Lock issue
- Who knows about the 1968 Toronado W-34?
- Quadrajet Identfication
- Decoding 1970 SX Cowl tag
- Kingston, NY anyone near there?
- smokin'
- Running 455 on battery
- 72 cutlass supreme springs
- 68 Cutlass/442 Core Support
- Dual Gate ID
- q-jet carb, need choke
- 67 442 cowl tag question
- 1971 455 alternater location
- 1970 442 id numbers
- Outside mirrors
- 68 442/HO Headlight Bezel Screws - Need A Pic
- Brake Backing Plate Finishes
- '68 A-body? RSML oddity on ePay
- !949 olds 98 Fuel Tank
- Weird '71 Saginaw Center Link - Anyone Know Anything About This?
- temp guage not working
- Exhaust Manifold Bolts
- shop manual '54 Rocket 88
- 93 Cutlass stalling w no codes
- Cutlass wagon fuel tank ???
- Fuel pumps and Ethanol, fact or myth?
- dual quad linkage
- How to test a radio.
- Anyone Please Help 89 olds 98
- Some More Interesting Details During 71 Tear Down
- Emission question
- Picked up a 70 Cutlass Convertable
- Starter
- Wagon Fuel Strap Brackets
- Differential/Cowl Markings
- Need help with 1964 88 Rlocker trim clips
- Speedometer Woe
- steering. column
- Headlamp Adjuster Source for Colonnade-Era Cutlass
- Repairing Fuel Line Seepage
- Correct Alternator Fan
- 71 442 wiper control knob removal
- climate control/heater defrost vent problem
- 65 Starfire frame
- Found a pic of my old 72 W-30
- 1962 394ci
- Need engine ID
- Rear coil spring direction
- How to refinish the faux wood steering wheel
- 1967 olds cutlass oil
- rocker aems
- Exhaust for my '66 Toro
- GM Part numbers
- Help - Hurst Dual gate into a 76 cutlass
- Rebuilding a 394 Fuel Pump
- want to convert to posi
- 4 sp. carb linkage
- Rearend carrier differences
- converting to 455 1972 cutlass
- 68/69 vs. 70/72 Wheel Well Interchange?
- Engine or Transmission Issue?
- 66 bucket seat metal question
- Exhaust system
- 66 4 barrel air cleaner
- Are These Dual Gate Neutral Safety Switches?
- Carb Float Question
- "keep your gm car all gm"
- 1967 Toronado- where is frame VIN stamp?
- 69 Heater box interchangeable with 1970
- Interesting Firewall Detail On My 71
- top frame interchange? 1966 Delta 88 'vert
- Radio Delete Questions
- Non-Olds Question about Chevy vortec 454 in my tow rig
- eary vs late flywheel diffs
- 1919 Olds capacities
- AC Delco part number needed
- 1970 Door Window regulator roller
- Restoring Tail Lights
- 72 Olds Delta 88 manual windows
- Has Anyone Aleady Done This OAI Set Up?
- 1972 442 exhaust tips
- 1968 tilt flocking shift to floor shift concersion
- Fan And Spacer Question
- Cold Natured Quick Fuel 750 Carb - Choke is closed
- Quadrajet Question
- Reproduction 8-track housing and pad
