Engine or Transmission Issue?
Old Dec 7, 2015 | 05:51 AM
TheBigBlueBoat's Avatar
Just curious to hear some others thoughts on the issue while I work on tying up some other loose ends around the vehicle.
The vehicle is a 68 Cutlass cruiser, worn out 350, 2-speed Jetaway transmission. It fires right up and runs, but putting it into gear causes the engine to lug down and die. It will free rev and roll in neutral just fine, parking pawl works fine. It appears to have plenty of clean fluid in it, though if it were down on fluid I would just expect it to slip.
I haven't had too much time to poke around the drivetrain yet, but I know the 350 is down on power due to worn rings (lots of smoke) from the get-go. But I'm wondering if the transmission is junk as well, and if so is it the converter or transmission itself? I have no experience with the Jetaway, or knowledge of it's common failures so anything is helpful.
Either way I'm not terribly worried since it came with a 455, TH400, and TH350 so if push comes to shove I have replacements. I'd just like to get it sorted out before I go to swap everything over so I can avoid doing things twice.
Thanks.
Old Dec 7, 2015 | 10:24 AM
It could be just that your tune settings are wrong.
Old Dec 8, 2015 | 06:13 AM
That very well could be. I haven't even had a timing light on it yet, and it's very clear it hasn't had the most dedicated (or competent) previous owners. Just as an anecdote they complained the back window was busted. Turns out the glue holding the bottom track of the window glass just dried out and separated. Everything was still there. Set it back right and it works perfectly.
I'll have to look into it some more when I get the time. Still need to sort out some wheel locks and brakes before then.
Old Dec 21, 2015 | 07:20 AM
Larry/car's Avatar
I agree, the engine could run but not have any power if timing is wrong. Selecting a gear could cause it to stall.
Old Dec 27, 2015 | 07:38 PM
64Rocket's Avatar
I'm more incline to say the converter is going bad. If so my opinion is to put a T-350 in it's place.
Gene
Old Dec 28, 2015 | 09:08 AM
rocketraider's Avatar
Oldsdruid
Is there any possibility someone has put a Switch Pitch Jetaway in there and it's stuck in wrong converter angle?
If you have the extra engine and transmissions and are going to use them, I wouldn't worry about the 350/Jetaway too much.
Old Dec 28, 2015 | 09:42 AM
Octania's Avatar
Aren't all the 2-spd Jetaways Switch Pitch? Maybe the converter was replaced with an incorrect type.
Out of tune is a good likelihood, since it has not been checked.
set timing with dist'r vacuum disconnected, then connect dist'r can to manifold vac, see if that works better. Might have to adjust the idle back down a bit.
Old Dec 28, 2015 | 12:54 PM
Not the 68's...
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
MrTorresJr
Nov 1, 2013 07:56 PM
MrCoolbreeze55
Jun 19, 2013 08:34 PM
boylost
Aurora
Aug 29, 2006 06:46 AM
