Rear coil spring direction
I belive on the rears there is a rubber isolator up top to quiet the ride down but the side that lays flat i would say goes on the bottom if there is a flatter side but from all the springs i have done i never really paid attention unless it was progressive rate ( cargo coils) . The fronts have a specific spot where the pig tail has to bump into. so the side that does not lay flat goes on the bottom control arm. For the rears i would say they are almost the same in my experience.
I remember one of Dave's posts many years ago saying the rear springs were oriented with the pigtails a certain way so the production workers could easily read the numbers on the tags when the chassis was coming down the line. If so, the orientation doesn't really matter as far as functionality is concerned.
70 manual section 4.3 states pigtails face left side for 31-48 series >
Probably not even that is needed. The coil spring is rotationally symmetric. Spring force is the same no matter how it's rotated. Unlike the front springs, both end coils of the rear spring are flat, so clocking has no affect on spring function or loads into the spring pads. At the front, the lower coil is open, so the design of the spring pocket in the lower control arm has a recess to accept this pigtail and clocking matters for that reason.
This all reinforces what I mentioned above, that one of the Daves had posted that the pigtail orientation shown in the assembly manual was merely to let the line workers easily see the tag on the spring and had nothing to do with functionality.
I must say that the last several posts have been extremely entertaining, in a non-Oldsmobile context.
Longhorncutlass
March 2nd, 2009 01:53 PM
