- Trunk Latch
- 1968 98 gas tank
- Correct vinyl top?
- Carb linkage bushing
- Speedometer Cable for 71 442
- early big block olds #
- 1959 olds 98
- 654 657 and 658 engine codes????
- rear springs
- W-30 cam 350
- Strong Gasoline Smell - 68 442 - 4 Brl QuadJet
- 67 4 speed throttle return spring
- 1970 442 alternator question
- Dash pads
- Air Cleaner Base OAI vs Non-OAI
- windshield trim color?
- 1970 OAI Secondary Hood Latch
- 67 W30 decal
- Body Mount Bolts
- 70 Disc Brake Metering Valve Stuck - Is It Bad Or Can It be Fixed?
- 72 442 Dashboard Indicator Light Inquiry
- PS pump; bare or paint?
- Fan shroud I.D.
- PS Pump Bracket Bolts 67 442
- distributor date codes
- 1971 Oldsmobile Cutlass receiving water
- 1964 Oldsmobile Data Tag
- Front end rebuild.
- Hood pop-up spring attachment
- Cowl Tag Decoding
- 1970 442 cutlass driveshaft question
- C Clip for steering column
- 69 442 end link torque
- Seat belts for a 1955 Oldsmobile
- Timing Tab Question
- Help with Reference Manuals '73 Olds 88
- Transmission Filler Flap
- Weatherstripping removal/replacement
- '70 Sport mirror part #
- Lower Windshield Trim Molding Tabs
- Cleaning out the 65 442
- 1979 403 starter and alternator number
- 1970 442 stripe color question
- Convertible Top Question
- Seat belt resto
- HELP! Flooding inside car!!
- Aluminum Pulleys for Olds Engines
- Break-in with both engine and transmission rebuilt
- coolant sticker positioning
- Correct Brake booster bore size.
- 455 engine assembly specs
- Marvel Mystery Oiler
- Ebay Billet Pulleys
- "Tubular Headers"
- Rapid Turns signal | Is it normal ?
- Starter Relay
- A/C Hose detailing
- 1966-67 442
- quietride hood insulation review
- remove a grease fitting from lower ball joint
- Electrical/battery question
- Help identifying 1973 Ninety-Eight rear end
- OEM vs repro inner fender wells
- Should I reuse stock pistons?
- steering column fitment
- Timing marks
- Belt Identification for 1977 Cutlass 350 Engine
- Starting issues !!!!!
- Lights
- Gas pedal 62 starfire
- 1965 f85 AC ice
- Type O axle vent?
- A Calendar Date On A 70 442 Brake Bracket?
- trunk weatherstrip/seal
- Window adjustment
- Shifter I.D.
- 64 Starfire Power Steering Quit
- To use or not to use pusher fan??
- 72 steering wheel play| tie rods, center link, etc replaced
- 68 Olds Cutlass heater & defroster cables
- A/C charging gages
- '70 442 - Heater / AC - Question on seals
- Cam angle
- What does the emblem mean for a 1964 Cutlass
- 1968 ninety eight gas gas pedal help
- 55 Olds oil filter base.
- Belt tension specification
- HDW question
- Hurst Lightning Rod Shifter Disassemble
- Location of "os" sticker on '69 4-4-2 air cleaner
- Cooling/Radiator questions
- Console/light package question
- Voltage at ignition coil
- Center console I.D.
- Ram air hood brackets on a 69
- 72 Cutlass disc/drum Master cylinder
- Shifter ID
- How to delete heater hoses under hood?
- Air cleaner thermostat
- Question about converting to electric fuel pump
- Number stamped on Starter mount?
- 67 442 coupe body mount bushings
- Crankshaft repair
- Quadrajet Damage- Locating pins
- Bumper I.D.
- Another part I.D.?
- Air cleaner I.D.
- Power trunk release I.D. and question
- Educate me on Oldsmobile engines
- 1969 Oldsmobile 442 identification help
- carburator W32 automatic Trans
- 1964 F85 help
- 70-72 Cutlass Trunk Lids ?
- fuel system help
- 1970 Vista Cruiser Seat Assemby Diagrams
- Help with some pricing of 70-72 NOS and other parts
- 67 442 Carb tag
- '68 Cutlass Washer Bottle Question
- 71 W30 Valve Covers
- 68 Cutlass Carb Choke Thermostat - 2V
- PAS Cooling
- Convertible top pump line leak - please help
- L7DD Tire code on 72 Build Sheet
- Frames
- Help,I need spark!
- How to Make a Metal Fuel Line from the Fuel Pump to the Carb
- 1969 Cutlass Supreme Front End Alignment
- Dual gate I.D.
- 1960 dynamic 88
- Power Driver Bucket Seat Mounts ????
- Slow fuel leak
- Guage I.D.
- Bolts and Fasteners 68 Cutlass / 442
- Trying to ID my childhood Olds!! Help!
- Best way to find part #s
- 65 Holiday Coupe VS Post
- Inner fender wells I.D.
- Restoration Shop Recommendation
- Hood and core support questions
- Replace speedometer
- Beginning of fuel line
- Alternator brackets
- Mechanic near Gainesville FL
- 62 starfire 394 ci
- 1970 442 over flow position with washer bottle and canister on passenger side
- 60 dynamic 88
- Brake booster
- 68 bumper filler
- Holley 6212 AAA 800 cfm Spreadbore
- 1995 GMC Sierra
- 1970 cutlass highcurrent alternator
- Fuel tank question
- Ignition advance references
- Car won’t run right - need help gang
- Power Steering Pressure Reducing Kit Use?
- 1970 Cutlass heater control valve with A/C
- 1964 Cutlass Hood Insulation Pad Which side goes out
- 70-72 Cutlass Interior Steering Wheel colors
- searching old dealers - Bill McCracken Oldsmobile
- Charles Maund Oldsmobile Dealer Austin Texas
- 1967 442 pin stripping and 442 front fender emblem placement
- Need some help
- Where do I find piston return springs
- 1969 doors
- 1955 Olds torus gasket question
- 84 307 Timing ?
- Correct Number Muncie for 65 442
- Carburetor
- Need Coil and alternator numbers
- 1972 cutlass core support tilting
- machine shop maryland va penns.
- Vin number on body question
- 1964 Oldsmobile dynamic 88
- Question on mechanics fuel pump and fuel lines
- Oil restrictors?
- 1982 Cutlass Supreme Brougham battery mounting
- Can't find cars computer.
- '67 Choke replacement/ fuel system (leave it carb or go injection) advice?
- Price check on some parts
- Re pop trim ( 1972 cutlass)
- Front upper control shims
- best method to remove 1955 Olds hood
- 371 Engine Ticking
- Early Hurst Line-Loc info wanted
- 1955 Olds piston cracks
- Emblem I.D.
- Heater box and missing pieces
- 1969 Wheels?
- Reproduction Core Supports - Anyone Buy One Yet? Howzit Fit?
- body side molding repair
- Help to identify this spindle
- Electric choke question
- Finding Fasteners
- 71 Cutlass Supreme Starting/Column Linkage
- Upper Rear Control Arms on '70 Cutlass
- Speedo cable keeps snapping
- Sport mirrors
- Speedometer Going Crazy, Grinding Noise
- FASTEN SEAT BELT warning light option
- '70 Cutlass Shift Lever End Assembly?
- Cruise control lever
- 1970 W31 Oddity In The PIM
- 1970 Heat Shroud mounting ?????
- Exhaust Manifold
- 1968-1972 Rear Bumpers
- Windshield Wiper Motor Differences
- Dual Exhaust?
- Engine inspection
- Air cleaner I.D.
- Door edge guards?
- Hood hinges
- Shroud
- When did olds put the highbeam switch
- 1967 442 heater core ??
- 1970 cutlass Heater valve
- How to find original GM part numbers
- Proper way to measure driveshaft
- Original calipers and frame components color
- Assembly manual
- Harmonic balancer
- need help a/c brace
- '68 Vista Front Coils
- Weatherstrip Right
- 425 verses 455
- Another HD cooling question
- '70 M21 Is Supposed To Be Original To The Car - Is It A Restamp?
- W & Z Manifolds - Are These Too Far Gone?
- Is This A OE GM M/T Flywheel?
- Hardlines For Quadrajet Question? (Electric choke)
- Engine pulleys
- Harrison radiator code confirmation
- Core support top plate
- Gone -tech library resource/data base
- '70 Olds Rallye Fuel / Brake Lines
- Differential Vacuum Delay Valve: 1984 Olds Delta 88 Royale
- what is the difference between 425 and 455 connecting rods
- O.A.I. air cleaner base I.D.
- 72 442 ?
- Question on 1972 Oldsmobile Cutlass supreme suspension rebuild kit
- T-stat housing
- '70 Convertible glass replacement: green tint or clear?
- Distributor cam plate
- Trunk lock rusted shut?
- Under dash heater core box interchange
- Four Door hard top doors on a flat top wagon ?
- 70 cutlass doors
- Alignment
- Unknown Parts
- anyone have '70 Lansing "12E" or "01A" cowl tag info?
