- How to Make a Metal Fuel Line from the Fuel Pump to the Carb
- 1969 Cutlass Supreme Front End Alignment
- Dual gate I.D.
- 1960 dynamic 88
- Power Driver Bucket Seat Mounts ????
- Slow fuel leak
- Guage I.D.
- Bolts and Fasteners 68 Cutlass / 442
- Trying to ID my childhood Olds!! Help!
- Best way to find part #s
- 65 Holiday Coupe VS Post
- Inner fender wells I.D.
- Restoration Shop Recommendation
- Hood and core support questions
- Replace speedometer
- Beginning of fuel line
- Alternator brackets
- Mechanic near Gainesville FL
- 62 starfire 394 ci
- 1970 442 over flow position with washer bottle and canister on passenger side
- 60 dynamic 88
- Brake booster
- 68 bumper filler
- Holley 6212 AAA 800 cfm Spreadbore
- 1995 GMC Sierra
- 1970 cutlass highcurrent alternator
- Fuel tank question
- Ignition advance references
- Car won’t run right - need help gang
- Power Steering Pressure Reducing Kit Use?
- 1970 Cutlass heater control valve with A/C
- 1964 Cutlass Hood Insulation Pad Which side goes out
- 70-72 Cutlass Interior Steering Wheel colors
- searching old dealers - Bill McCracken Oldsmobile
- Charles Maund Oldsmobile Dealer Austin Texas
- 1967 442 pin stripping and 442 front fender emblem placement
- Need some help
- Where do I find piston return springs
- 1969 doors
- 1955 Olds torus gasket question
- 84 307 Timing ?
- Correct Number Muncie for 65 442
- Carburetor
- Need Coil and alternator numbers
- 1972 cutlass core support tilting
- machine shop maryland va penns.
- Vin number on body question
- 1964 Oldsmobile dynamic 88
- Question on mechanics fuel pump and fuel lines
- Oil restrictors?
- 1982 Cutlass Supreme Brougham battery mounting
- Can't find cars computer.
- '67 Choke replacement/ fuel system (leave it carb or go injection) advice?
- Price check on some parts
- Re pop trim ( 1972 cutlass)
- Front upper control shims
- best method to remove 1955 Olds hood
- 371 Engine Ticking
- Early Hurst Line-Loc info wanted
- 1955 Olds piston cracks
- Emblem I.D.
- Heater box and missing pieces
- 1969 Wheels?
- Reproduction Core Supports - Anyone Buy One Yet? Howzit Fit?
- body side molding repair
- Help to identify this spindle
- Electric choke question
- Finding Fasteners
- 71 Cutlass Supreme Starting/Column Linkage
- Upper Rear Control Arms on '70 Cutlass
- Speedo cable keeps snapping
- Sport mirrors
- Speedometer Going Crazy, Grinding Noise
- FASTEN SEAT BELT warning light option
- '70 Cutlass Shift Lever End Assembly?
- Cruise control lever
- 1970 W31 Oddity In The PIM
- 1970 Heat Shroud mounting ?????
- Exhaust Manifold
- 1968-1972 Rear Bumpers
- Windshield Wiper Motor Differences
- Dual Exhaust?
- Engine inspection
- Air cleaner I.D.
- Door edge guards?
- Hood hinges
- Shroud
- When did olds put the highbeam switch
- 1967 442 heater core ??
- 1970 cutlass Heater valve
- How to find original GM part numbers
- Proper way to measure driveshaft
- Original calipers and frame components color
- Assembly manual
- Harmonic balancer
- need help a/c brace
- '68 Vista Front Coils
- Weatherstrip Right
- 425 verses 455
- Another HD cooling question
- '70 M21 Is Supposed To Be Original To The Car - Is It A Restamp?
- W & Z Manifolds - Are These Too Far Gone?
- Is This A OE GM M/T Flywheel?
- Hardlines For Quadrajet Question? (Electric choke)
- Engine pulleys
- Harrison radiator code confirmation
- Core support top plate
- Gone -tech library resource/data base
- '70 Olds Rallye Fuel / Brake Lines
- Differential Vacuum Delay Valve: 1984 Olds Delta 88 Royale
- what is the difference between 425 and 455 connecting rods
- O.A.I. air cleaner base I.D.
- 72 442 ?
- Question on 1972 Oldsmobile Cutlass supreme suspension rebuild kit
- T-stat housing
- '70 Convertible glass replacement: green tint or clear?
- Distributor cam plate
- Trunk lock rusted shut?
- Under dash heater core box interchange
- Four Door hard top doors on a flat top wagon ?
- 70 cutlass doors
- Alignment
- Unknown Parts
- anyone have '70 Lansing "12E" or "01A" cowl tag info?
- Rear spring help
- Assembly Date
- z bar help
- Cowl tag decoder
- Could a 1969 442 (not Hurst) have a factory 455 in it?
- Help With A/C
- Power Steering Brackets
- manifold question
- Washer pump on when wipers on
- Binding throttle cable question on 1971 Cutlass
- Supercharger
- Downloadable 1976 Cutlass Parts Manual Sought
- Rebuild parts quality dropping, who do you trust door what?
- Remote door mirror cable routing
- Idiot lights
- Stall Converter
- wiper motor ground strap
- 350 to 455 in 70 Olds
- Bolts and fasteners
- Tire Pressure decal material question
- cruise transducer year
- 67 Cutlass vin decoder
- 67 Cutlass auto floor shifter placement/location
- Van Ness Oldsmobile window sticker info wanted
- Wiper & Washer Repair Parts Source
- Door Lock Repair
- Wipers won't park
- Throttle cable issue
- Air Breather Tube?
- A little mystery on the last drive of the year!
- Hood Tongue question
- Phantom fuel leak
- Head Gasket Question
- Water Pump casting numbers
- Gas cap leak advice wanted
- Edelbrock carbs
- 1969 442 convert trim codes
- New Window Sweeps (felts) with proper fit
- '66 Brainbeau lettering pics
- Is this the proper carb?
- 1966 Toro Intake Manifold
- 67 Cutlass door glass diagram
- Hood Latch
- 67 Cutlass Convertible Top Measurement
- 1972 442 Convertible
- Oai
- Convertible top frame?
- Rotted body pieces
- Fuel tank sender unit for 1968 Toronado
- Tell me about telltales....
- DECODING original options for the car
- 69 Cutlass/442 frame assembly component colors
- 73 Cutlass cowl tag
- Factory Style Mufflers
- Won't start after sitting several days.
- Car Misfires When Cold
- 1971-72 Cutlass supreme package shelf
- exhaust
- 68 cutlass stainless steel fuel tank
- What do these fit?
- Name that Part!
- Brake hoses for 1959 Dynamic 88
- '78 Cutlass L/H remote mirror cable swap?
- Questions about dropping the gas tank
- Help w/head ID
- Ram air
- 87 Cutlass Supreme (Steering Column)
- Smogger 455 vs 1971 350
- 1972 442 convertible rocker panel moldings
- 67 Cutlass radiator overflow
- Vacuum diagrams
- Help with Cowl Tag Decoding
- 1968 Olds Cutlass Adaptor Defroster Repair
- 65 4GC Carb (442) Vent Tube to Fuel Bowl
- 71 Cutlass Conv Questions
- 54 Defroster Switch Removal
- High beams
- Fuse Blowing
- 67 Cutlass Options
- Can anyone name this part? Where can i get one? Thanks Guys.
- Fall Carlisle vs. Fall Hershey swap meets
- 70 442 rear hood molding vs. 69
- 72 442 Tachometer issue
- Fast EFI - 495 Olds Motor
- Quadrajet throttle shaft
- Rallye 350 Cowl tag trim code help please
- '55' Wiper/washer vacuum line
- Who wants to play what the heck is this?
- 67 Delmont 88 ignition switch
- Correct Steering Column Cover_1968 Olds Cutlass S
- Heater Box Correct Gaskets
- Correct Heater Hose Clamps
- 1985 307 v-8 delta 88 vacuum lines
- 70 Cutlass Convertible Top Cylinder Replacement/Install
- Restoring 71 Supreme cast grilles
- Rear Speaker Bracket???
- Is this Dual Gate shifter from Olds or Pontiac? What year?
- What year is this 4spd shifter?
- 1969 442 Core Support Shims (As Required)
- 72 Cutlass Swap Header Compatibility
- convertible top fluid
- 1969 cutlass splash shield installation advice
- 1984 Speedometer jumps, but cruise works Advise wanted
- 70 Cutlass Fuel Gauge / Sending Unit
- 68 buket seat
- choke ?
- HVAC controls on 67 Delmont 425
- Metering rods
- 62 starfire interior paint
- Identifying a 1970 OAI Hood
- Difficulty level 1-10 ?
- Windshield wiper linkage restoration
- Vintage Air AC/Belt What Size?
- 394 and webber carbs
- Convertible top cylinder sizes
- "0" miles question
- 68 W31 Air Cleaner Decal
- Muncie and Chevy 12 Bolt Lube--Interchangeable??
- sound deadner
- yellow Interior
- 1970 442 pinstripe vinyl tape roll
- 1969 cutlass a/c options,universal under dash or Vintage Air?
- AC question
- 64 pitman arm
- vacuum advance
