Front upper control shims
Old Mar 13, 2018 | 08:11 PM
Classics65's Avatar
Does anyone know what the factory settings we're for the shimming on the front upper control arms for a 1965 Starfire? I can't find the amount of shims needed in my 65 chassis service manual and I'm getting ready to start putting my front end together. Any help is greatly appreciated!
Old Mar 13, 2018 | 09:17 PM
Shim amounts are determined by a front end alignment.
Old Mar 13, 2018 | 09:27 PM
Classics65's Avatar
There's no factory setting or just take to an alignment shop when it's done?
Old Mar 14, 2018 | 06:21 AM
I would put enough shims in to get the camber close, adjust toe so that the fronts of the tires are in 1/16-1/8" over the rears, and then take it to an alignment shop that knows older cars. Not a franchise shop like Sears, Pepboys, or Meinecki.
Old Mar 14, 2018 | 06:50 AM
Run to Rund's Avatar
I bought the Longacre tool for setting camber and caster, and use a tape measure and straight boards to set toe-in. Alignment could be pretty far off if you just wing it, making the handling very bad. Collect some shims, clean and paint them. Having a variety of them is well worthwhile.
DR_DAN
Mar 9, 2015 05:48 PM
jfb
May 6, 2014 06:26 PM
68442CONVERTCO
Drivetrain/Differentials
Apr 7, 2011 04:38 PM
lshlsh2
Body work
May 24, 2010 04:41 AM
Ron King
Dec 13, 2009 08:29 AM
