Edelbrock carbs
The Edelbrock carbs are the design from early 60’s Carter AFB. Just made shiny today.
Here are some thoughts, facts, and some opinion tossed in.
Pros,
will sit on almost any engine, start, idle and run.
Mass produced and easy to find and purchase.
Cons
Requires adapter plate if placed on Quadrajet intake
Doesn’t provide best performance without proper calibration changes. Can be dangerously lean at sustained higher rpm.
Typically provides limited performance.
Best replacement for an old Quadrajet? For best fuel economy and performance, get yours properly rebuilt. Or replace with proper Quadrajet for your application.
Pros,
Cons
I ran an Edelbrock carburetor on my 64 98. It was VERY streetable with perfect idle and good off-idle response. Unfortunately, I couldn't get it to work properly with the Slim Jim Rotohydramatic transmission. This was due to the POS transmission, not the carb.
Now, I have a Summit 750 cfm carb on my 71 98. It is a clone of a Holley 4010. It has nowhere near the drivability as the Edelbrock. Should have bought an Edelbrock... oh well.
Ageed. If you are thinking about the Edelbrock carb because you think an aftermarket carb will make more power than the original carb, you may be disappointed.
Don't have any use for Qjets either, real hard to get a good, flat fuel curve.
I know Mark and many otbers like the Holley style Quickfuel carbs, very tuneable and no issues out of box. The Street Demon will bolt on either square or spreadbore manifolds. It is a 3 barrel design, heavily borrowing it's design from the Carter Thrrmoquad, the AFB's replacement. Holley made it more user friendly and eliminated some of the design flaws like crappy choke, eliminated main body o rings that fail and a Aerospace polymer main body in place of the bakelite one. Plus works with OD trans and has a TPS option. I had a good Qjet 800 cfm 78 core and sent it to Everday Performance for a custom tune and rebuild. It came out a few bucks cheaper than a new 750 Street Demon and their TV bracket. I think the power piston selection is key in the Qjet's curve. I also like the APT on the Qjet. I added a thread in plug and notched the APT adjuster for a small standard screwdriver, 2 turns either made it burn the tires or gain 3 mpg.
Like Christian said, for the money, I believe the QF stuff is the best. Look at the fuel curve on the 374 build I posted last week. This was after 1 jet and 1 air bleed change, done.
70Cutlass_408
Jun 24, 2011 07:55 AM
