manifold question
Old Dec 11, 2017 | 03:16 PM
denf221's Avatar
manifold question
72 cutlass supreme, 350 automatic, A/C My driver's side manifold is cracked and need to replace it. Can someone recommend headers that would perfectly fit without any alterations?
Old Dec 11, 2017 | 04:18 PM
I don't think those headers exist, as in the best fitting ones still need a slight amount of work for adequate clearance. I have Heddmans on my car and while they fit very well, I had to slightly flatten one tube on the drivers side so the inboard corner of the lower control arm wouldn't contact it at full suspension travel.
Old Dec 11, 2017 | 11:14 PM
Gerald Nickels's Avatar
Thornton makes a new cast iron header that flows more than stock 350 exhaust manifolds. try them.
Old Dec 12, 2017 | 06:39 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Either the Hedman or Sanderson shorty headers need 0 mods to fit, other than modifying the down pipes to fit on the collector with the stock starter. Use aluminum or copper collector gaskets.
Old Dec 12, 2017 | 06:59 AM
76olds's Avatar
Hookers under Hood
As Olds307and403 mentioned:
If you go with the short header such as hedman. The photo below is from my 76 cutlass supreme with 350/350.
With hedman shorties, this type of custom mandrel pipe is likely what you will need to do coming off the driver side header.
I used Remflex graphite header gaskets.
silverriff
Jan 30, 2010 12:35 PM
Olds64
Aug 5, 2009 03:17 AM
grt05
Jul 20, 2009 05:00 AM
rustyold66
Jul 2, 2009 07:44 PM
nonhog
Jan 23, 2009 01:09 PM
