Under dash heater core box interchange
Old Jan 8, 2018 | 12:42 PM
Jacoz70442's Avatar
I've got a '70 442 w/A/C and need to get a new under dash heater core box. Does anyone know what years and if it interchanges w/other GM A-bodies that year(s)?
Old Jan 8, 2018 | 01:14 PM
I was all set to say that the 68-72 A-bodies use the same firewall and HVAC box, however the parts book shows different P/Ns for 68-69 and 70-72 F-85 series. The heater core is the same, however. Apparently the differences are in the vacuum valves and flapper doors. I SUSPECT (but don't know for sure) that you can swap the entire assembly as a unit. Of course, the ducting that bolts to the box is unique due to dashboard and vent configurations.
Old Jan 8, 2018 | 01:20 PM
Jacoz70442's Avatar
Joe, Thanks so much. I've got a A/C heater box assembly out of a 72 Cutlass S that I wanted to check to see if that works...looks like it will match up with the outside condenser box. Whew! Always interesting seeing what will interchange and what won't.
Kennybill
Jul 17, 2017 06:28 AM
ros6872
Apr 25, 2014 09:31 AM
1956OldsDarrin
Oct 14, 2012 07:13 AM
goodkarmech
Oct 24, 2010 06:19 AM
jeffs 89 cutlass salon
Oct 22, 2007 12:46 PM
