- Where to Install Second Coolant Temp Sensor for EFI
- 72 Supreme - Mufflers Recommendation
- Radiator seals..
- 1968 Cutlass S Gas Vent
- A/C hose assembly
- Repair or replace - Lower rear shock mount
- throttle position sensor "still" showing code
- Vehicle id before vin
- 64 cutlass wheel well trim repair
- Repositioning 71 455 points distributor
- Accelerator pedal questions
- Are these all the same?
- Ported or Unported Vacuum Advance-Dist ?
- please help identify 1950's convertible power window regulators
- Height of Power Bucket Vs Manual Bucket 72
- duel point distributor w/ mechanical tach drive
- Manual Brakes vs Power Assist
- Comfortron
- 14x6 steel wheels
- 1964 Olds Cutlass holiday coupe resto
- Engine fitment for my 1979 “rocket” 350 in a 1984 g body
- Best place to buy parts
- Air Conditioning question
- Rear harness guide/guard?
- gaskets
- Rebuilding Lifters - Yes or No
- A/C Delete and heater box cover plate
- 70 supreme build sheet question
- diesel starter
- What is this relay looking thing?
- Oldsmobile cutlass ciera 1988 3.8
- 69 w30
- 69 w30 4-speed
- Brake booster. Late 70's gm B body ?
- Electric fuel pump fuel tank
- 67 seat belt bolts
- Correct radiator replacement
- Cutlass decal for 69 Cutlass
- Led bulbs?
- 1966 Oldsmobile A/C
- 1970 442 Piston question V or U notch tech questions
- Self tapping carb inlet filter for Rochester QJ
- 70 convert trunk question
- Help with part numbers
- Weight of E Heads
- 66 442 HD Cooling Fan Clutch Recommendation
- Glove box lock removal without a key?
- 62 olds dynamic 88 engine block aqua green paint
- 330-425 valve cover baffles
- 71 Cutlass HVAC rectangular hose
- 1969 cruise control - revisited
- 72 350 Supreme Breather Question
- 68 Cutlass S Steering Column
- 1968 / 1969 speedometer differences?
- 89 regency 98 water pump replacement
- 1970 Cutlass Fuel Tank Vent Hoses
- Hurst Dual Gate 2 neutral safety switch (68/69 Cutlass)
- Carb help
- Lower steering column bearing
- 1968-1969 Cutlass blower-type rear window defogger
- Rear Brake Lines and Hose Assembly - '70 Cutlass
- Mysterious vacuum can
- interior windshield defrost vent duct tube housing?
- Mallory distributor ID
- newb post about finding general parts for Rallye 350 from chain stores
- 1968 rear side marker lights
- Oil change
- Need 1968 Oldsmobile A-body non-tilt floorshift steering column diagram
- Transducer repair/rebuild '69 4-4-2
- 60 degree spark plug boot
- 1947 series 66 front end questions
- Roller rocker advice
- chrome plating wheels
- E85 and Fuel Sending Units
- W-30 Harmonic balancer
- brakes
- general questions
- Motor mounts 69-72 a body
- 68 442 electrical rewiring
- Another Special Part Replated By Sparky's
- Body mount color
- Help with 10 bolt rear gear ratio ?
- 67 442 Drip Rail Mldg.
- 1965 olds cutlass gas pedal
- 12 bolt type O or 10 bolt Oldsmobile rear end
- 68 442 pulleys
- Bolt on exhaust options | Dougs headers
- Interpret Casting "Clock" Symbols
- Steering column question
- Torque wrench selection, calibration, recommendations
- Looking for advice.
- 72 Cutlass Radiator Replacement
- Removing AC
- 67 C/S 330 eng, harmonic balancer
- Mirror ID
- Cowl Tag Decoder
- Engine temp fluctuating
- How to Bolt hood latch on
- Build sheet question..
- '68 442 400 c.i. Engine Bay Paint Types
- Help with W-25 Hood lock bracket
- Rear axle sticker
- Help with transmission identification
- Intake question
- 1972 Convertible - Lube Top?
- 1964 F85 clutch fork spring.
- 58 horn fittings
- 1972 Gas Tank Vapor Lines
- vac hose routing
- Wiper Transmission Hardware Questions
- Real 442?
- 1966 O.A.I. bumper bezels
- What is this thing
- Some help and advice on a couple of things
- 66 seat belt retractor disassembly
- Bellhousing date code
- correct 72 POA Valve
- 1967 442 Hose Clamps
- Tachometer
- 455 oil pan gasket replacement.
- Build dates
- '70 power bucket seat track knowledge needed
- Windshield Wiper
- Pressure gauge video
- Can I assume that if I have a 400 E code block
- 1964 F85 Z bar bushing
- Length of Olds 400 push rods
- Rochester 4 GC 58 Oldsmobile 371
- 67-68 3 spoke steering wheel.are they the same?
- Steering column key lock problems 72 ish column
- 68-72 rear upper control arm difference
- 330, 400, 425 WhIch Parts Interchange?
- Power steering pump
- Tilt steering column numbers
- What is it for??
- Cylinder key lock help. PLEASE!!!!!
- 69 Olds 442 Thermostatic Vac Switch Routing
- Racing Quadrajet Builders - West Coast
- 72 CS black steering column
- Doorman 603-001 recovery tank
- My new Spectra Premium tank was defective
- 1968 keys
- 69 Olds 442
- 1988 Delta 88 heat issue
- 1955 Olds differential exploded view.
- Steering column interchangeability
- Worth cleaning fuel tank?
- 1966 l69 3x2 throttle base plate number ??
- Parking Brake Adjustment
- 68 Hurst Olds air filter
- Cutting Keys
- Looking for info from a '65 to '70 Pontiac parts book
- A Pillar Seals for 65 Cutlass vert
- 394 engine technical specs
- 1970 Cutlass emissions stickers
- Anybody have a 1970 Toronado service manual...
- Dash Vent Duct
- Wrong hood hinges? Can't adjust? '70 Cutlass
- 394 air cleaner/ valve cover 4 barrel
- 307 aluminum intake value
- "Dust" Seal for Floor Shifter(?) / '68 442
- 455 Plugs and Gap
- Difference between 1969 & 1970 Cowl Panel
- Safely testing manifold vacuum on distributor vacuum canister
- Cutlass Windshield Differences?
- New from ILT..
- '68 442 / Correct Air Filter Cover & Housing Color
- '68 442 / Vent Window Regulator
- 425 and 455 best of both worlds?
- Name those parts?
- Can I place my jackstands here?
- olds water pump
- 1967 442 lower column bearing
- SBO Power steering for street rod
- OPGI 65' Fan Shroud
- 1967 442 gas tank sending unit removal !!
- "A" body question...
- 3.08 or 3.73?
- 1971 Cutlass SX radiator replace or restore?
- Correct jack color
- Oldsmobile Facts Book
- 71 VC Starter
- Has anyone tried this?
- Cowl tag decode
- unknown Parts?
- 64 cutlass heater speed control bulb
- 89 Toronado BCM BD90 / BD 91 codes
- olds 394 engine number
- Body mounts
- Replaced my fuel pump and lost half my gas mileage...
- 1950 cowl tag decode
- 66-7 A - body 4dr P/W ID
- 5 on 5 disk brakes
- Water pump 61 dynamic88
- 394? Camshaft identification
- Core Support pressed in retainer nuts 5/16"
- Legit 442
- Mechanical fuel pump pressure
- 1992 oldsmobile 98
- Rochester float level
- Any harm in too small fuel return line? '68 4-4-2
- Dash datum Line and CL of Car
- IDing the flywheel 1964
- Steering column ignition switch lockout
- 1968 Cutlass Headlight Bezels
- Core support I.D.
- 48 257 flathead valve clearance settings
- Transmission mount
- Another front coil spring thread - ball joint removal necessary?
- Pillar post trim and seals 72 cutlass convertible
- Body Mounting Bolts
- 64-65 Cutlass door handles
- 70 starter numbers
- Gasket ID
- 1964 Starfire distributor interchange
- 455 blue paint code ??
- 1972 Cutlass dealer specs booklet...
- N47 option
- Power steering pump spacers
- Power Steering pump bracket bolts
- 72 CS Ash tray springs replace
- Hard pedal
- Original Pwr Steering Pump Pulley?
- 58Air Conditioning advice!
- Radiator Express ?
- Need help getting 425 going
- R12 to 134A Refrigerant
- 72 vert with 68 445 Running rough
- Various trim levels on 66 442
- 71 cutlass ignition switch/key turn is tight all of the sudden.
- Super tuning/blueprinting olds "w" machines
- 1970 W31 fuel sender replace via trunk ?
- Can a coupe technically be a sedan?
- Start-up Advice
- installing 455 with 7 1/2 quart pan
- Confirm Door Sweeps are 70 Cutlass 442 Convertible?
- ‘72 Olds Knocked Off Today, locked in Park?
- Decoding Starter Stamping
- '69 Cutlass Air Conditioner warm air from right vents
- 58 olds compensater/pulsator fuel pump
- 58 with A/C - Expansion valve
- Master cylinder question
- Carb identification
- 442 emblem font type and size
- 66 Air cleaner
- oil pan
- Headers In a 66 Jetstar
- 70 Cutlass Single to Dual Exhaust Conversion
- Inner fender grime shields
- 1967 CS Holiday Coupe Spring Rate
