PDA
View Full Version : General Questions
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21
  1. 1970 350 pace car values?
  2. 1970 350 pace car
  3. Unicorn issue
  4. 68 vent window restauration
  5. 1966 Starfire engine vs Super Rocket engine
  6. Replacing radiator / Adding transmission cooler '97 Olds 88
  7. hard steering
  8. 89 olds cutless supreme els 2.8 6cylinder
  9. '84 Cutlass window sticker ?
  10. 1972 Cutlass Supreme Vapor Canister
  11. Amount of Freon in AC system needed
  12. Harmonic Balancer Rebuild
  13. Need help locating taillight lens screws.
  14. Distributor #
  15. Need to be informed about my F32
  16. Correct master cylinder
  17. 495 Stroker Oil Pressure
  18. 1968-69 Fender question
  19. 1970 Ingition lock function tilt floor shift
  20. Motor mount bolts
  21. 1967 442 Shoulder Belt Saddle Location
  22. Metal shavings from AC compressor
  23. Parts Identification - 67 Cutlass 442 Convertible
  24. water pump bolts
  25. Original mirror position 88
  26. Dash pot
  27. Headers for performance 455 in a delta 88
  28. 1969 442 Transmission Pan Color?
  29. Body By Fisher Decode
  30. Oil smells like fuel?
  31. Head Code Stamp Question
  32. Body tag decoding help? 65 Vista Cruiser
  33. Wiring question.
  34. Wiring Identification Issue
  35. altenator issue
  36. Rear window seal
  37. PCV nipple on intake
  38. 69 Rally Gauges w/ Tach Wiring
  39. Molding Identification Needed
  40. brake line fitting
  41. Clutch to flywheel bolts
  42. 1979 Camel Tan interior paint?
  43. How to remove a corroded bolt?
  44. Valve Cover Recommendations
  45. 2002 Intrigue 3.5 head gaskets any advise on changing them.
  46. Need a seatbelt expert
  47. 1971 442 Documentation
  48. door window foam insulation material
  49. 1956 interior dash color paint codes
  50. 307 5a
  51. 1971 Engine Code
  52. Oldsmobile's Obscure RPO Codes
  53. Oil cap gasket
  54. 442 hood hinges
  55. Correct Radiator code & tank codes for a 71 Cutlass 455 w/ AC?
  56. 4 speed back-up light switch
  57. 68 cutlass /442 front suspension colour
  58. Air conditioner gasket/ weather stripping
  59. Need help decoding a 64 cutlass body vin
  60. 64 Starfire cowl tag?
  61. Oil pan removal
  62. Recommended car covers
  63. 68 400 block numbers decode
  64. Flare repair
  65. 67 Cutlass Radiator Hoses
  66. 67 cutlass tach
  67. 7040256 1970 W-30 4 speed carburator
  68. Purpose of splines on base of lug studs
  69. Power window motor Rebuilder (who has a good one)
  70. Rochester 4gc
  71. 67 Cutlass Frame
  72. Olds parking brakes
  73. Power Window Boot
  74. E3 plugs
  75. Power Steering Pumps
  76. Plugs from hell or All plugged up.
  77. Water Pump for my 66 442 with A/C
  78. 68 Hood Hinges.
  79. Steering Box Bolts
  80. Vintage Air in a '65 Cutlass/442
  81. How to fix Washer Reservoir
  82. Shift Lever Demand Wiper - Motor Label
  83. Rear mounting strap for 8 track player
  84. Shat-R-Proof Windshield date code
  85. Smoke or steam dash vent issue
  86. Need Help
  87. Air Cleaner date stamp - repro available?
  88. Another 71 442 cowl tag
  89. 71 442 conv body tag decoding help
  90. Anyone ever try the Anco washer rebuild kit?
  91. What is this?
  92. Which Fuel Tank Sending Unit for 1976 Cutlass?
  93. 67 cutlass kickdown
  94. Oldsmobile in Action Vol. 1 anyone have a copy?
  95. steering columns
  96. A bodied frames
  97. 442 VIN and body tag
  98. Header ideas for 1990 B Body (Box Wagon)
  99. Demand Wiper Motor Label
  100. building a 350 for a wagon, tq converter question
  101. Any idea the year model for and 8 track part number ending 51971
  102. Engine rebuild 394
  103. Where can I find matching numbers
  104. Spare tire mount bracket pictures needed
  105. Coolent Recovery Advice
  106. Transmission stamps question
  107. 1970 442 Air Cleaner base not painted inside?
  108. 70 OAI questions
  109. 1970 Rally Steering Wheel
  110. 425 heads
  111. Correct Finish on maker light brackets
  112. Olds Heads
  113. Overheating after intake manifold replacement
  114. 71 Cutlass A/C part ID and location help
  115. Dropping Oil Pan but this is in the way on Jetstar 1
  116. 74 Cutlass
  117. W30 and 442 horsepower numbers
  118. Fan clutch preference
  119. Car shuts off
  120. What is a good cam for a 403 , for street use ...
  121. AC wiring questions
  122. 1968 442 colors
  123. Bracket
  124. intake manifold difference?
  125. 70 AC brackets
  126. Exhaust and carb
  127. 91 cutlass supreme 3.1 died and won't start
  128. Cooling fan clutch
  129. 1974 fender tag decoding
  130. WZ manifold exhaust studs
  131. Wiring harness?
  132. Help Please 70 Cutlass Convertable W30 Tribute
  133. cooling fan?
  134. car broke down will not start, its not the battery...
  135. Vista Cruiser Qs
  136. 74 Cutlass Data plate
  137. What is this no:2?
  138. What is this?
  139. Shift indicator removal on the cosole
  140. Odd part search: reinforced 90deg hose bend
  141. new owner of 72 cutlass S
  142. 72 Supreme Directional lamp issues
  143. Which ATF ?
  144. Power top switch replacement
  145. 1957 98 Olds trunk lids
  146. MSD Ready To Run Timing curve?
  147. Starter differences between 350 and 455
  148. Air cleaner base with HEI?
  149. Upper control arm bushings
  150. Unknown Part Identification
  151. Dual exhaust
  152. Cutlass won't start for some reason
  153. fuel not getting to carb
  154. 65 vista cruiser/cutlass fender trim
  155. Manual for 1972 Cutless Supreme
  156. looking for part# for alt,starter,77 cutlass
  157. 1970 RPO codes
  158. What engine oil to use to reduce blow by for 1974 oldsmobile cutlass supreme
  159. How?
  160. Bleeding Brakes; This one has me stumped.
  161. Help with 68 442 (1 year only) lower hood latch clip
  162. Best car cover
  163. Transmissions avalable in 64
  164. 67 442 Battery Cable Routing Pics
  165. 1980s Mondello Catalogue info wanted
  166. 69 442 interior mirror light
  167. Spark Plugs
  168. hurst shifter linkage 67-68
  169. harmonic balancer
  170. 1965 cutlass vent window remove , convertiable
  171. AC hoses
  172. Trunk rod installation tool
  173. Need Help With My Horn
  174. Wiper Refills
  175. 72 V code Supreme, 1 of 77
  176. 66 Heater Hose Routing ?
  177. Oil Filter Housing Gasket
  178. 10 OHM Resistance Wire Question
  179. Fall cleaning :]
  180. Windshield Washer Pump Rebuild
  181. Can you identify this trunk lock cover?
  182. Windshield fogging problem
  183. Spare tire issues....Bravada
  184. Timing question
  185. Cooling system Question
  186. Decoding a 442 VIN number
  187. Shift handles
  188. 1967 Oldsmobile Cutlass ignition key mechanism
  189. 67 oldsmobile cutlass trunk rods
  190. Source for 69 A/C Duct
  191. Column mounted dimmer switch replacement
  192. 1993 Olds 88 Royale LOCKED TRUNK HELP
  193. 72 Cutlass Brake line
  194. What are these and can I....
  195. Relief for Rattling Colonnade T-tops!
  196. EGR and gas mileage
  197. Manifold gasket
  198. Carb rebuild
  199. Rebuilding A/C '77 Cutlass
  200. 68 Cutlass AC Box - Valve Covers
  201. NOS 7027156 Qjet
  202. sport mirror replacement glass size
  203. '76 Cutlass 350 A/C Belt Length Needed
  204. Power Bench Seat
  205. I want a Tachometer...HELP!
  206. Points issue
  207. Crank verification
  208. Eldyn
  209. Diesel flexplate
  210. W-30, W-31 Intakes in regards to engine paint
  211. Thickness of floor/trunk metal
  212. Galleon Gold 1970 paint
  213. Cable/Wire Throttle Pedal - Cutlass 1971
  214. exhaust manifold bolts on 425
  215. Starter
  216. 1967 Cutlass Antenna Illustration
  217. Alternator Help
  218. Steering Column mounting issue
  219. molding for a 1961 Olds 98 Town Sedan
  220. 1993 Olds 88 Royale - Steering column - ignition busted
  221. 65 olds f85 alternator
  222. When should the body go to the shop?
  223. 1970 Olds Cutlass "S" package tray part number?
  224. Seeking Tuning Advice/ Vacuum Reading Interpretation
  225. Books
  226. production #s for 70 w30 special order colors
  227. Main bearing cap bolts
  228. 350 seems a lil crooked -gbody
  229. '70 Cutlass PS Pump bracket diagram/pic
  230. stock tac
  231. Axle and Final Drive Assembly Manual
  232. Strange Issue
  233. Fluids for 72 cutlass
  234. Heater/bypass hose clamps
  235. G-Body cutlass 307 frame mounts
  236. 76 98 - Advice Needed
  237. Stock 63 Amp alternator VS higher amp
  238. 1976 Oldsmobile Cutlass Supreme
  239. 1971 cutlass s question
  240. Bumper Jack location in trunk and bumper to jack sticker location on lid?
  241. Advice for Installing Air Cleaner Decal Correctly
  242. Edelbrock Carb Rich/Lean, which way is which?
  243. 1984 olds delta 88 307 starting problem
  244. 1977 cutlass Dash
  245. Carb ID
  246. 1965 Olds 400 timing mark question
  247. 1970 W-31's & TVS Solenoids
  248. Still confused--350/450 swap
  249. Will a 69 window reg work in a 72
  250. Under Dash Insulation
