1967 Cutlass Antenna Illustration
Can someone post from a 1967 Cutlass assembly manual the radio non power antenna illustration. I need to do some comparison work for my 66 Cutlass, front fender mounted antenna assembly. I am trying to avoid buying a 67 assembly manual that I don't need.
Wayne
Wayne
66/67 should be rhe same except the mast. I will be going back to the doctor on Thursday and if he puts me back on my feet,I'll check the 66 unit if you can wait.
Mike, there is no rush. just wanted to compare the units when I pull the wipers and grill off. I have no idea whats in there. I just ordered a tool to use from Dorman. Hope you are feeling better.
Wayne
Wayne
marxjunk
June 25th, 2014 02:42 PM
SteveH
March 24th, 2012 03:29 PM
