I want a Tachometer...HELP!
It would be helpful had the OP told us whether he wanted a bolt-in tach or a generic aftermarket that required a little work to fit. If generic then yes, any 3 3/8 aftermarket will work.
look at the link i posted...it goes right in the clock pod..
here it is again...it just bolts right in the clock pod and matches your speedo..its a direct bolt in..i have one in a car..neat stuff..
http://www.gmsports.com/tachometers-and-gauges?page=2
Is the wiring harness/connector already in the dash to connect the tach? Any mods needed for the wiring? Thanks!
