PDA
View Full Version : General Questions
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. 442 Vac Advance Timing? Max total?
  2. 69 olds 350 timing issues
  3. What do you guys think about this?
  4. Heater box restore
  5. After market AC
  6. 394 cranks drilled?
  7. 72 CS Cowl Plate help
  8. plate vs flat steel
  9. Windshield Wiper vacuum diagram for 1955
  10. Older Parts Manuals
  11. Where to get a new carb from
  12. 1968 Oldsmobile Cutlass Supreme - Frame off Restoration - Disc Brake/Suspension
  13. W30 tuning sticker under the hood
  14. cowl tag help 72 CS
  15. Harrison radiator education
  16. Fan shroud
  17. Fan & Clutch Part #'s for 70 W30?
  18. Page needed for assembly manual
  19. Nss i.d.
  20. 400370 W30 Head #s
  21. Body mounts
  22. Part I.D.
  23. 1108418 starterapplication.
  24. 66 e brake light
  25. Engine pulley part number
  26. 70-72 4 Barrel Throttle Cable
  27. mirror fastening
  28. build sheets or documentation
  29. 70 W30 Intake lift hook question
  30. ID Help needed
  31. Build sheet question
  32. 1970 W31 Engine photos
  33. Convertible speaker configuration
  34. Clutch Linkage Painted or not?
  35. 1960 Oldsmobile Super 88 heater vacuum lines
  36. 1970 Cutlass Steering Wheel
  37. 71 assembly manual
  38. Retractable antenna
  39. 70 442
  40. Will this fit | 72 Cutlass trans, drive shaft, rear question
  41. 65 Steering Column
  42. Truck owners blocking Tesla Superchargers
  43. heater core in my 72 olds cutlass
  44. gm cross reference ( obsolete parts)
  45. 1965 Starfire fuel issues. Carb floods when car is turned off.
  46. non ac pulleys with driver side alternator mounts
  47. Help with 1964 Data Plate, first Olds
  48. W25 hood trim piece? Questions and comparisons
  49. 67 442 pcv hose
  50. Clutch fan part #
  51. Traction off
  52. '70 "OW" transmission tag, REAL?
  53. '73 Carb# 7043250 Electric Choke Conversion and Questions
  54. Windshield washer hose
  55. A/C parts interchange
  56. No trunk sticker
  57. 62 starfire
  58. Where do these go?
  59. Old Gas Tank/line '70 Cutlass
  60. 71-72 Tailights
  61. 64 steering wheel quandary
  62. washer bottle screws
  63. Unused 66 front bumper bracket
  64. Shifter base difference
  65. HF stencil on 66 M21
  66. Help, 66 F85 assembly manual
  67. Air shock valve stem bezel? Sticker?
  68. 67 coolant temp sensor
  69. Headliner to A pillar
  70. Help With 1968 OAI W30 Air Cleaner Vacuum Line Routing
  71. Ballast Resistor required?
  72. Converting Carb to Electric Choke
  73. 72 Cutlass replace front speaker
  74. door trim removal
  75. Speedometer Calibration
  76. 72 | Fuel Tank and Sending unit details
  77. 71 W30 Sound Deadening Material
  78. Installing 67 Olds Cutlass Oil Pressure Sensor
  79. 455 exhaust sound
  80. 1972 CS vacuum line help
  81. 57 Olds Super 88 4BBL Carburetor
  82. 55'-56' Front bumper question
  83. Bumper Jack
  84. 70 Motor Mount - Not The Usual One
  85. Missing 8 track piece?
  86. 1965 Jetstar 1
  87. Drilling Holes for Hood Pins
  88. new front disk rotors | bearing races pre installed
  89. Info is tall 57/58 rear end in 55 olds 98
  90. 1967 olds delta 88 vacuum diagram
  91. Hood latching questions
  92. 71 Heater Control Valve Issues
  93. 1970 442 - What PS Fluid?
  94. dual gate
  95. Carb numbers
  96. Heater Temp Slider
  97. 1955 88 A/C Outlet Location
  98. Hard-to-remove Lifters
  99. Hardware Packages for Restoration
  100. Grounding lug at PS bracket 67 442
  101. Frame resto
  102. Vent window rubber replacement?
  103. ignition dinger?
  104. low pressure PS Gearbox hose fitting
  105. Help ID a restamp?
  106. Oldsmobile Cigarette Lighters?
  107. Body manual
  108. 68 Cutlass Convert frame question
  109. 1st day of production
  110. 68 442 windshield wiper motor
  111. Replacement timing cover issue...
  112. 70-72 Reverse Lamp Lenses - What Is Correct?
  113. Ram Rod 350 literature?
  114. Cleaning the trunk
  115. Factory build quality (or not)
  116. No AC and Heat
  117. Toronado killing when leaving red lights
  118. AC Delete
  119. Looking into getting an '83 custom cruiser
  120. fuel pump I.D.
  121. Radiator recommendations?
  122. 86 Ciera engine swap
  123. Fuel tank venting
  124. General questions
  125. Rally Pak Gauge Face - Any Ideas?
  126. Trunk Latch
  127. 1968 98 gas tank
  128. Correct vinyl top?
  129. Carb linkage bushing
  130. Speedometer Cable for 71 442
  131. early big block olds #
  132. 1959 olds 98
  133. 654 657 and 658 engine codes????
  134. rear springs
  135. W-30 cam 350
  136. Strong Gasoline Smell - 68 442 - 4 Brl QuadJet
  137. 67 4 speed throttle return spring
  138. 1970 442 alternator question
  139. Dash pads
  140. Air Cleaner Base OAI vs Non-OAI
  141. windshield trim color?
  142. 1970 OAI Secondary Hood Latch
  143. 67 W30 decal
  144. Body Mount Bolts
  145. 70 Disc Brake Metering Valve Stuck - Is It Bad Or Can It be Fixed?
  146. 72 442 Dashboard Indicator Light Inquiry
  147. PS pump; bare or paint?
  148. Fan shroud I.D.
  149. PS Pump Bracket Bolts 67 442
  150. distributor date codes
  151. 1971 Oldsmobile Cutlass receiving water
  152. 1964 Oldsmobile Data Tag
  153. Front end rebuild.
  154. Hood pop-up spring attachment
  155. Cowl Tag Decoding
  156. 1970 442 cutlass driveshaft question
  157. C Clip for steering column
  158. 69 442 end link torque
  159. Seat belts for a 1955 Oldsmobile
  160. Timing Tab Question
  161. Help with Reference Manuals '73 Olds 88
  162. Transmission Filler Flap
  163. Weatherstripping removal/replacement
  164. '70 Sport mirror part #
  165. Lower Windshield Trim Molding Tabs
  166. Cleaning out the 65 442
  167. 1979 403 starter and alternator number
  168. 1970 442 stripe color question
  169. Convertible Top Question
  170. Seat belt resto
  171. HELP! Flooding inside car!!
  172. Aluminum Pulleys for Olds Engines
  173. Break-in with both engine and transmission rebuilt
  174. coolant sticker positioning
  175. Correct Brake booster bore size.
  176. 455 engine assembly specs
  177. Marvel Mystery Oiler
  178. Ebay Billet Pulleys
  179. "Tubular Headers"
  180. Rapid Turns signal | Is it normal ?
  181. Starter Relay
  182. A/C Hose detailing
  183. 1966-67 442
  184. quietride hood insulation review
  185. remove a grease fitting from lower ball joint
  186. Electrical/battery question
  187. Help identifying 1973 Ninety-Eight rear end
  188. OEM vs repro inner fender wells
  189. Should I reuse stock pistons?
  190. steering column fitment
  191. Timing marks
  192. Belt Identification for 1977 Cutlass 350 Engine
  193. Starting issues !!!!!
  194. Lights
  195. Gas pedal 62 starfire
  196. 1965 f85 AC ice
  197. Type O axle vent?
  198. A Calendar Date On A 70 442 Brake Bracket?
  199. trunk weatherstrip/seal
  200. Window adjustment
  201. Shifter I.D.
  202. 64 Starfire Power Steering Quit
  203. To use or not to use pusher fan??
  204. 72 steering wheel play| tie rods, center link, etc replaced
  205. 68 Olds Cutlass heater & defroster cables
  206. A/C charging gages
  207. '70 442 - Heater / AC - Question on seals
  208. Cam angle
  209. What does the emblem mean for a 1964 Cutlass
  210. 1968 ninety eight gas gas pedal help
  211. 55 Olds oil filter base.
  212. Belt tension specification
  213. HDW question
  214. Hurst Lightning Rod Shifter Disassemble
  215. Location of "os" sticker on '69 4-4-2 air cleaner
  216. Cooling/Radiator questions
  217. Console/light package question
  218. Voltage at ignition coil
  219. Center console I.D.
  220. Ram air hood brackets on a 69
  221. 72 Cutlass disc/drum Master cylinder
  222. Shifter ID
  223. How to delete heater hoses under hood?
  224. Air cleaner thermostat
  225. Question about converting to electric fuel pump
  226. Number stamped on Starter mount?
  227. 67 442 coupe body mount bushings
  228. Crankshaft repair
  229. Quadrajet Damage- Locating pins
  230. Bumper I.D.
  231. Another part I.D.?
  232. Air cleaner I.D.
  233. Power trunk release I.D. and question
  234. Educate me on Oldsmobile engines
  235. 1969 Oldsmobile 442 identification help
  236. carburator W32 automatic Trans
  237. 1964 F85 help
  238. 70-72 Cutlass Trunk Lids ?
  239. fuel system help
  240. 1970 Vista Cruiser Seat Assemby Diagrams
  241. Help with some pricing of 70-72 NOS and other parts
  242. 67 442 Carb tag
  243. '68 Cutlass Washer Bottle Question
  244. 71 W30 Valve Covers
  245. 68 Cutlass Carb Choke Thermostat - 2V
  246. PAS Cooling
  247. Convertible top pump line leak - please help
  248. L7DD Tire code on 72 Build Sheet
  249. Frames
  250. Help,I need spark!
