70 Disc Brake Metering Valve Stuck - Is It Bad Or Can It be Fixed?
Old Aug 21, 2018 | 06:21 PM
costpenn's Avatar
I was cleaning this valve up for a resto I'm doing. After cleaning the rubber cup and wirewheeling the body, I notice the valve seems to be stuck. I can't move the metal stem in any direction - should it be very hard to move or is it stuck? Can it be serviced or should it just be replaced?
Old Aug 21, 2018 | 06:37 PM
The seals are just o-rings. If you can get it apart, you should be able to hone the bore and replace the o-rings. You will likely need to match up the old o-rings with new ones from a source like McMaster Carr.
Old Aug 22, 2018 | 06:14 AM
oldspackrat's Avatar
I have 1 or 2 if it can't be rebuilt.
Old Aug 22, 2018 | 07:19 AM
ROCKET VAPOR's Avatar
Lance
Replacement parts
https://www.musclecarresearch.com/gm...ing-seal-kit-2
Instructions
https://www.musclecarresearch.com/gm-1233464-rebuild
Old Aug 22, 2018 | 08:11 AM
costpenn's Avatar
Thanks to all - ordered the rebuild kit and got the diassembly instructions.
1k442
Brakes/Hydraulic Systems
Jul 3, 2017 10:05 AM
jensenracing77
May 28, 2013 02:15 PM
Mark71
Mar 26, 2013 06:05 PM
mmurphy77
May 2, 2011 08:09 PM
buds68a77
Feb 5, 2009 04:15 PM
