394 cranks drilled?
Old Feb 19, 2019 | 08:56 PM
jakedog3wfwf's Avatar
394 cranks drilled?
Does anyone know whether all 394 cranks are drilled for manual trannys? I have found two 394s that have slim jims attached. I need a manual tranny application.
Old Feb 20, 2019 | 06:49 AM
Charlie Jones's Avatar
Phantom Phixer
The only 394 cranks that were drilled for a manual trans , were the ones that came with a manual trans . Slim to no chance of finding one of those !
However , Automatic trans cranks can be easily drilled by any competent machine shop ,
You will need a pilot bushing , Dorman # 690-014 ;
https://www.ebay.com/itm/1Qty-Dorman...frcectupt=true
The crank will have to be drilled to 7/8 in. about 1 and 1/2 in. deep and then finished machined to .003 less than the OD of the bushing ( for an interference fit ) .
The finishing cut should only go the depth of the length of the bushing . Then the bushing should be pressed in . Put about 1/2 teaspoon of grease in the cavity behind the bushing for lubrication .
I got the crank for my 394 drilled and the bushing installed for less than $100 at Sackett's Machine Shop in Orlando .
Here's an illustration ;
Old Feb 21, 2019 | 11:09 AM
Thanks Charlie. I will see what I can do about purchasing these motors.
Old Feb 21, 2019 | 11:36 AM
OLDSter Ralph's Avatar
Thanks for the info Charlie.
Delmont 88 PA
Sep 9, 2014 08:07 PM
oldzkool
Feb 15, 2014 02:52 AM
T butter
Jun 5, 2013 07:06 AM
Railguy
Oct 30, 2011 09:57 AM
