mirror fastening
Old January 21st, 2019, 03:31 AM
turbo57's Avatar
mirror fastening
i dont know how the mirror i stucked to bracket. Anyone have a photo or something that show how ?
turbo57 is offline
Old January 21st, 2019, 06:02 AM
I do not know whether this illustration will work for your application on your vehicle. I think you have a 65 98? Here is a diagram from a 1971 to help provide you with a general idea.
Vintage Chief is offline
Old January 21st, 2019, 06:58 AM
Texas69's Avatar
Mirror
For what its worth, 1969 Cutlass is similar to the diagram posted. Special bolts are threaded into bottom of the mirror, then fed into the keyhole slots in door. I think the bolts are reverse threaded.
Texas69 is offline
Old January 21st, 2019, 07:30 AM
turbo57's Avatar
Thanks for your answer
Correct my car is 1965 98. No that illustration is not showing what i have. Bracket on my car is mounted with 2 screw in door. One earlier owner have cut a bolt and mounted so the mirror only is in place, so it is not steady, and it is not screwed on the bracket . I suppose there must be some sort of halfround bushing, washer and nut where the wires can go clear instead of that cutted bolt ?????????
turbo57 is offline
Old January 21st, 2019, 07:49 AM
There are two screws in the mirror bracket in the above illustration. They are identified in both locations. Since your installation has already been 'modified' it's difficult to suggest how you might install your mirror. It appears you'll need to perform another modification? I don't know. As I said, this is a general illustration. IMO, you can either attach the base plate form the outside>in, or inside>out, and you 'could' do the same with the mirror attachment to the base plate. Just be certain you do use the base plate, since it does provide the additional support when the mirror is mounted so you're not using only the door metal. Sometimes these things require a little ingenuity when they have already been modified by a PO.
Old January 21st, 2019, 07:54 AM
Sorry, it does not. The OP's mirror requires a mounting bracket that I do not see in his photo.
joe_padavano is offline
Old January 21st, 2019, 07:55 AM
Thanks Joe.
Old January 21st, 2019, 07:58 AM
This drawing is 1967. The 1965 mirror is similar. Keep in mind that not every Olds is the same as the 68-72 A-body cars.
Old January 21st, 2019, 08:02 AM
Hot diggity dog biscuits - that's an illustration.
Old January 21st, 2019, 08:47 AM
turbo57's Avatar
Thanks for your answers
I have problem to explain in word, a picture say more than 1000 word
Some parts is missing here and i must try to manufacture those
with bracket
turbo57 is offline
Old January 21st, 2019, 08:52 AM
So you do have the bracket? If so, you just need to drill three holes in the door, two for the sheet metal screws and one for the cable to pass through.
Old January 21st, 2019, 08:58 AM
I think his bracket is missing the tab for the upper draw screw that pulls the mirror back to lock it on the mount.
oldcutlass is offline
Old January 21st, 2019, 11:18 AM
turbo57's Avatar
Thanks for your answers again
As i told i have problem to explain what i mean
The mirror was mounted on car, but the cutted bolt is laying loose in the cromed foot part,, it is something missing for keep it in the right place on that part, the bracket screwed on door is ok
turbo57 is offline
Old January 21st, 2019, 11:22 AM
I'm sorry as I realize you're trying, but I can't really understand that. Can you post photos of both sides of the bracket. I believe Eric is correct about the missing tab on the bracket.
Old January 21st, 2019, 12:28 PM
turbo57's Avatar
Something must hold footpart and mirror together
The little screw on footpart, hold it to the bracket and the bracket fits on door, but footpart and mirror must hold together with something, thats the 10000 dollars question
turbo57 is offline
Old January 21st, 2019, 01:57 PM
jaunty75's Avatar
I think the problem is that the tab into which the screw that goes in at an angle is broken. I've circled the tab and screw in red the diagram and where it's broken off in yellow in your photo. Without this tab, there is nothing for the mounting screw to screw into, and the mirror will not stay in place. I have the same thing on the rearview mirror on my '67 Delta 88, but mine is not a remote-control mirror.
As you put it, " footpart and mirror must hold together with something." The "something" is that tab, and it's missing.
jaunty75 is offline
Old January 21st, 2019, 02:02 PM
jaunty75's Avatar
Here's the mirror on my car, and I've circled the screw in question. On the OP's car, the hole on the bracket into which this screw screws is broken off.
jaunty75 is offline
Old January 21st, 2019, 07:43 PM
His bigger problem is that the round mirror head and swivel ball aren't attached to the chrome base. It appears to be missing a nut of some sort.
Old January 21st, 2019, 09:11 PM
Yup that would be problem #2, but easier to fix.
Old January 21st, 2019, 10:04 PM
turbo57's Avatar
Nice, Joe have reached the problem i have. I must make those parts but it should be fine to know how they made them from factory so i can copy them.
Thanks for all your help so far.
Leif
turbo57 is offline
Old January 25th, 2019, 03:15 AM
turbo57's Avatar
How i will make this work ?
I cant fint original parts ( i think they was bigger), but i think this will work. Fingerwasher with spring steel. It is trial and error
turbo57 is offline
Bunser
August 31st, 2019 04:35 PM
bassinguy
November 27th, 2018 07:18 AM
glickstein
June 18th, 2018 07:08 AM
Gamblin Jones
January 31st, 2012 10:18 AM
nitrojunkie1029
Tech Editor's Desk
November 2nd, 2011 01:38 PM
Quick Reply: mirror fastening
