1965 f85 AC ice
Old Jul 19, 2018 | 03:57 PM
Daniel Alborn's Avatar
1965 f85 AC ice
Hey guys, my f85 is experiencing an issue where the AC input line before the evaporator is icing up (along the suction throttling valve). My AC is quite hot and I'm driving this car around in the Florida summer. The car has a full charge of r12a (Freez12). I noticed that a vacuum nipple had broken off the white vacuum canister on the blower housing, does this have anything to do with the suction throttling valve or the airflow accross the evaporator?
If my stv is what is causing the issue, how can I go about testing it for proper function?
Thanks,
Dan
Old Jul 19, 2018 | 04:18 PM
Didn't know there were two lines to this, but I guess I now know where that loose vacuum line goes. I'll try to repair the broken off center nipple
Ice appears all along the circled line, is this the output of the evaporator? If so then I bet the issue is my air door not opening.
Old Jul 20, 2018 | 12:16 PM
Icing up sounds like either a low refrigerant charge or a restriction in the line.
bruneau
Tech Editor's Desk
Jul 10, 2019 01:55 PM
jh48
Oct 1, 2018 08:12 PM
lesclark65
Mar 15, 2016 06:26 PM
71 OLDS
Nov 29, 2012 01:41 PM
nuttkaze
Jun 4, 2010 06:53 AM
