Correct Brake booster bore size.
Evening all !
While at the OCA Nationals I might be looking for a Brake booster and Master cylinder set up to install during my front end rebuild and front disk brake conversion this Summer. So here is my question regarding the brake booster. I will be using an 11 inch Delco Moraine brake booster, since that was what was original on the car. I needed to know the booster's bore diameter size that would be correct for my 1972 Cutlass Supreme with power brakes, front and rear drums at this time. I don't want to pull mine at this time since all is good and I don't want to jinx the car 4 days before the OCA meet.
Evening all !
Bore size
plee3 64Olds
Brakes/Hydraulic Systems
Apr 28, 2011 10:01 AM
