68 Cutlass Convert frame question
Old Oct 2, 2018 | 03:53 PM
68442droptop's Avatar
Anyone know for sure if a 71 Skylark Convert frame is the same as a 68 Cutlass convert frame. Lots of people say all the a body frames from 68-72 are the same (except hardtop and convert of course), but does anyone know if there are specific differences or if a 71 Skylark convert frame can be used on a 68 442 convert without any modifications?
Old Oct 3, 2018 | 11:14 AM
I think the frames are interchangeable, as long as the body style and wheelbase is the same
Old Oct 3, 2018 | 05:48 PM
Yellowstatue's Avatar
The one difference I can think of is; the brake line on a '68 is in the middle of the cross member and the later years it is moved outboard about seven or eight inches. Therefore you would have to check the hole for the brake line and get the correct flex line to match.
Old Oct 3, 2018 | 07:34 PM
SmirchIs#1's Avatar
There are two small differences that I have seen,but they are still interchangeable,The shape of the rear crossmember that the upper trailing arms are bolted to are shaped different where it is welded to the frame rails.Also the welded tab at the front center edge of the crossmember under the engine will usualy be different between years and models
Old Oct 4, 2018 | 05:05 PM
allyolds68's Avatar
I knew Greg Godon had replied a few years ago to a question Joffroi had about frame differences. He was wanting to put a 70-72 convertible frame under his 68 convertible. I had to dig back four years
Here it is:
Originally Posted by rcktdoc
68 frames are different in a couple places than the 70 and up frames. above the rear end at the arch the 68 is shaped to clear the inner wheel house on 70-72 they laid the frame at an angle in that spot, and the front crossmember is shaped different than 69 and up.The front is only estetic.
Greg
and this
.......they notched the 68/69 frames to clear the inner wheel houses. The 70-72 frames arent nothced. You may want to check clearance on your existing frame where the wheelhouse comes closest to the frame over the rearend.
Greg
and this:
......all 68-69 frames are dished at the arch above the rearend on the outside of the frame rail, The 70-72 frames arent dished.
Greg
The whole thread is here:
https://classicoldsmobile.com/forums...-how-goes.html
Freddy B
Oct 6, 2018 03:58 PM
servexcell
Apr 6, 2015 02:56 PM
sparky44268
May 25, 2014 05:43 AM
Bernhard
Jan 2, 2013 09:16 AM
firefrost gold
Nov 6, 2011 05:45 PM
