- Cracked block...can it be welded?
- 70 455 id and value?
- Carb Numbers Question
- fuel tank venting
- delco coil 442 1970
- Another Carb Problem
- carb problem
- Vacuum line hookup for OAI
- Dual exhaust ATTEMPT
- brake info
- Looking for aTrustworthy Olds Mechanic near Pasadena Ca.
- Reliable Parts Suppliers
- 1970 VIN Sequence
- Matching Numbers or not??? 1967 CS
- car show swap meet
- Part Number Identification
- Rear tires
- 455 Swap
- Question about keys...
- Cowl Tag decipher - vinyl top or not?
- Where can I get a cowl seal that lets the hood close
- electronic ignition/ power coil question
- '76 Coupe Deville sway bar
- DIFFERENTIAL SWAP
- Xylene/Toluene into the Tank for octane boost. Bad Idea?
- '66 Power Steering Fluid?
- How many 72 Cutlass
- overheating
- 67 del mont88
- 1970 Cutlass Supreme Data plate Decoder?
- Lost Trunk Key
- GM 9985062 Cement
- vented/not vented gas caps
- choke not working
- 68 Cutlass Vert cowl decoding
- FB Broadcast card
- Charging Question.
- Edelbrock 1406 problem?
- Cold Air vs. Ram Air Intake?
- Determining if 45 or 39 degree with intake off
- VIN discrepency??
- '68 4-4-2 TURNPIKE CRUISER
- What does numbers matching mean?
- Manual dissapointment
- autronic eye
- Any ideas
- Comfortron crazy
- Tring to figure out what motor it is
- Removing Decal on Rear Bumper
- preping heads for brazing divider?
- Degree a cam
- J2?
- Moisture and Blow-by problem
- Advice on Restoring a 455
- Parts exchange manual
- Holley Carbs in my 63 F-85 Convertible 1963
- '67 442 Bolt color
- electrical problems
- Dipstick problem
- Anyone know what this is ??
- 67 Valve cover sticker placement
- 1972 Cutlass S exhaust questions
- 1969 442 Build Sheet(S)?
- 1965 425 or Toro oil pan ID question
- radio instalation
- 1973 olds 98
- What fluid in conv top motor ?
- Gear ratio on 67 Cutlass ?
- Water Pump Question
- tire decision
- '64 vista question
- Installing air conditioning....HELP!!!
- '68 442 FAN DOESN'T WORK RIGHT
- Engine ID ???
- Fuel Union Size
- Help..67 Cutlass fan...4 to 6 blades ?
- 72 cutty exhaust ?????
- Can anyone decode this oilcap!
- Rebuilding air conditioning system on Cutlass
- Convertible Frame Repair
- Inner Fender Reconditioning...
- Stuck on P/S pump
- 1972 Quarter Window Seals
- Distributor question
- oil pump 350 rocket
- Photos of Casting Number Locations, Engines
- Photobucket
- Gas Tank Sending Unit Gasket
- 76 Custom Cruiser power door locks
- '67 442 Data Plate....tough one!!!
- Gas Tank sender hiting tube?
- Gas Tank- How Big
- How wide is the 70 cutlass s?
- Intake Air Quality
- I need help Id'ing this engine/trans
- Variable Vane Torque Converter Switch
- Start after long storage--advise needed
- stone shields
- My New Oldsmobuick
- Oldsmbile Calais GT
- Q-Jet and ALT decode?
- newnie with 67 olds cutlass 4 door.
- Gas tank needed
- Stupid question - Crank bolt which way to turn??
- Radiator Leak -- 1960 Olds
- floor shifter problem
- Where on the block is the engine code
- Good Sound for 66 Olds 442
- vacuum reservoir
- What arethese spindels off of?
- 75 88 blower resistor part # help
- 76 455 cooling system
- 76 olds 350
- Oil pan modifications
- Ignition switch R&R - is there an easy way?????
- Spark Plugs 3.1 liter V-6
- 1960 dual exhaust changeover
- New to site need information
- followup question on 82 olds with diesel
- Carb Question
- Factory paint Daubs
- stone shield
- Air cleaner
- Gas Question, Leaded or Not?
- '61 Radiator Interchange
- valve covers
- ?? Rear End
- Water Pump help
- Console ??
- Flywheel question
- What year are these dog dish caps?
- Any Suggestions?
- Engine knock
- DATED PARTS
- 371 VS 394
- Right oil & fluids
- rallye 350
- Weatherstripping and seals.
- Roof rail weatherstrip install
- Exploding Muffler
- Wiring for side winder tach.
- hello to all...
- 1970 protecto-plate decode
- Where is the engine Number
- will gto wheels fit a cutlass superme?
- Vacuum canister. Do I need it?
- Engine questions for new 72 Cutlass
- newbie here...what oil should i use in my 371??
- Oil pressure switch-sender
- Question on crank case ventilation
- Olds Rochester Carb.
- First attempt at using timing light on 65 Cutlass
- Splitting Ball Joints
- ignition starter switch
- beheaded cutlass
- Emission Control or lack there of
- 64 OLDS CUTLASS HARDTOP
- 330 ci rebuild. Need advice
- droping oil pan
- 2 Olds 4V intakes 567184 - help Newbie ID please
- to port or not to port?
- Looking for Help on wheel/tire size
- Just bought a 1957 J2
- how to tell 350 from 455 in 1970 olds
- Decode
- Hurst Shifter his and hers
- 350 alternator
- Muffler Suggestions?
- Front crankshaft seal
- heater setup
- Wich oil do you suggest for a 69 Cutlass conv. 350
- Switching from 350 to 455
- Synthetic Oil - 63 super 88
- hidden vin numbers?
- Fuel Pump ID
- Vacuum intake modulator
- Header Panel Help????
- 1969 - 98 hood hinges
- black W30 decals NOS part # 404615
- Big Block on an Engine Stand
- Mystery Noise
- Pre 71 gas additives
- Engine not getting hot enough?
- Carb Problem
- PIC Request- 55 and 56 Engine compartments!!!
- 68 442 tick toc tac conversion
- Timing chain questions...
- Tune up for a 1956...
- 307 HO/442 mpg??
- 442 emblems on 69
- tire/rim question
- Starting a golden oldie
- Timing chain
- waterpump - heatercore
- juggling trans question
- matching numbers
- Question on vaccum trunk opening
- 303/371/394 swaps
- 69 442 fender emblem locations
- The early Olds V8's
- 455 exhast manifold
- 1980 Olds Cutlass
- greeting from texas, restoration question
- Horsepower
- HELP!!!! Never bought an Olds need some expert opinions!
- hood hinges
- Front and rear springs for 61-62 full size
- 455 manifold
- 1987 Cutlass Salon won't go into gear
