Starting a golden oldie
Old Feb 12, 2009 | 06:03 PM
CHARLOTTE's Avatar
BigJ91104
Hey guys I'm in the process of confiscating a 1962 olds 98 with a 394 rocket from my father. It was his when he was in high school, and I was interested in rebuilding it. The one catch is that it has been sitting for oh about 15 years. The good news is that it appears to be sound with the exception of surface rust. My question is..... what is the best way to start it up after it has been sitting for so long? My current plan is to replace all the fluids of course, clean the fuel tank of any debris and, replace the battery. What other suggestions do you guys to ease the process.
Old Feb 12, 2009 | 09:30 PM
59-59-59's Avatar
If it was mine, I would also change the oil, oil filter, remove the distributor and spin the oil pump rod with a drill and 1/4 inch extension ( 5/16 socket I believe) to get the engine lubricated and verify if you have oil pressure. Taking the spark plugs out and squirting oil down the cylinders wont hurt either...just alot of smoke out of the tailpipe
Old Feb 12, 2009 | 11:37 PM
dan2286's Avatar
Make sure you can turn the engine over by hand first. It might save you from some major headaches.
Old Feb 13, 2009 | 07:55 AM
citcapp's Avatar
Welcome to the site CHARLOTTE the two pervious answers are the way to go. Also change the spark plugs, points, and distributor cap. Replace the fuel filter. Good luck
Old Feb 13, 2009 | 09:04 AM
redoldsman's Avatar
Proud Viet Nam Veteran
All good advice here from some very good veterans of Oldsmobiles. When you put the drill on the oil pump to turn it, be sure you turn it counter clockwise. Putting the oil in the cylinders is the way to go. I would probably use something like Marvel Mystery Oil and let them soak a day or two. Be sure and turn the engine over several time to be sure you don't have a stuck valve. If it stops, don't force it very much. You might have to pull the valve covers to see if the valve are moving if it won;t turn. ONe note of caution, make sure the distributor is in when you turn the engine so you don't have to screw with the timing. Mark where the rotor is pointing on the distributor and mark the distributor to the engine before you pull it out. There is also a good chance you will have to drop the gas tank and have it flushed and sealed. Be sure and blow the line from the tank to the fuel pump out and be sure it is not rusted. Good luck.
Old Feb 13, 2009 | 05:20 PM
CHARLOTTE's Avatar
BigJ91104
Thanks guys. As soon as I talk him out of it I will post some before pics. Its going to be awhile before we get to the after pics though, but thats half the fun.
Old Feb 14, 2009 | 03:19 PM
Oldsguy's Avatar
Past Administrator
Charlotte, welcome to our site and get that thing running, we wanna see some pictures too.
Old Feb 22, 2009 | 05:52 PM
CHARLOTTE's Avatar
BigJ91104
HERE ARE A FEW PICTURES I TOOK WHEN WE DRUG THE OLD GIRL OUT OF HER RESTING PLACE OF 20 + YRS. SHE was LAST TAGGED IN 82.
Old Feb 22, 2009 | 06:18 PM
CHARLOTTE's Avatar
BigJ91104
I THINK MY PICS ARE TOO BIG, HOW DO I SHRINK THEM TO 92KB SO YOU GUYS CAN SEE THEM
Old Feb 22, 2009 | 10:37 PM
Yellowstatue's Avatar
Smile Start project
As with all great projects, this one should also start with winding the clock...
Old Feb 23, 2009 | 04:11 AM
csstrux's Avatar
I just use the stretch skew option in Microsoft photo editor. There is probably a better way, but it works. Welcome to the site. That is one heck of a nice project by the way. I am looking forward to seeing that one come to life
Old Feb 23, 2009 | 07:35 AM
citcapp's Avatar
The best and most interesting are the ones brought back from the dead. Good luck with the build. We look foward to more pictures
Old Oct 30, 2012 | 07:36 PM
CHARLOTTE's Avatar
BigJ91104
plans change
Well guys......As the title says, my plans changed. What started as a simple get her running, turned in to a complete resto. I ended up having a stuck piston that I damaged getting out. Damage meant a bore of +.04 and I decided to replace all the pistons. Here we are two years later, and I almost have the motor back together. My self diagnosed ADD wont let me stay focused on just one thing at a time, so I have pulled the interior completely, removed the body from the frame, removed the surface rust from the sides, and primed the cleaned up sides. Had a baby girl a year ago, so progress has been rather slow going. Newly acquired free time has reignighted my interest, and I am getting back to work on her again. I will try to post a link to the latest pictures in a week or two. The sight has been great for parts and advice thus far. I look forward to getting her done, and keeping you guys posted on my progress.
Old Oct 30, 2012 | 07:53 PM
Seems eerily to apply to this thread.
Spooky.
Old Oct 31, 2012 | 03:01 AM
If you can wait a while longer, your daughter can help!!!
Old Oct 31, 2012 | 06:18 AM
Well I'm glad your still at it. Post some pic's of your progress.
Old Oct 31, 2012 | 02:05 PM
Seff's Avatar
I'm gonna have to see this.
Old Mar 31, 2019 | 01:50 PM
CHARLOTTE's Avatar
BigJ91104
Moved this build to the major projects page with some photo updates. Finally running after 35 years, and man she sounds good. Bought a pertronix, but currently running off a set of points. Two kids in, and both helped on her last weekend. See you guys in another 10 yrs when I finally get the body back on.
Old Mar 31, 2019 | 03:31 PM
OLDSter Ralph's Avatar
The points will easily last for the next ten years.
63hardtop
Jul 26, 2015 09:34 AM
coconv
Oct 6, 2012 03:04 PM
grt05
Apr 12, 2012 04:56 AM
BerBer5985
Oct 13, 2009 08:45 PM
Cesar Malta
Jul 11, 2007 08:24 PM
