Ignition switch R&R - is there an easy way?????
Old May 10, 2009 | 01:11 PM
gearhead1218's Avatar
Like the title says.
Is there an easier way than what the service manual says with less disassembly????
Looks like it's going to be a royal P.I.T.A.
Old May 10, 2009 | 03:20 PM
My442's Avatar
Be more specific....are you talking about the where the key goes or the actual switch itself?
Old May 10, 2009 | 04:08 PM
OK, the key cylinder on a 70. Non-tilt, floor shift, automatic tranny.
I have a complete set of cylinders for the whole car, keyed for one key only.
Old May 10, 2009 | 04:41 PM
rocketraider's Avatar
Oldsdruid
Of course there's an easier way. It's called a slide hammer. Car thieves have used it successfully for years.
'Course odds are you'll bust the column doing that. R&R a lock cylinder is actually not that hard, just requires a steering wheel puller and a lock plate removal tool. You can probably rent both at a parts store, but you can buy them about as easy and then you have them next time.
Old May 10, 2009 | 06:18 PM
Let's be clear that we're talking about the lock cylinder, not the ignition switch, correct? You need to pull the steering wheel and the lock plate. The web site below covers the lock cylinder removal as part of a repair that goes deeper into the column, but just stop at the lock cylinder step.
http://buickperformance.com/tiltstee...lumnwobble.htm
Old May 14, 2009 | 05:14 PM
Thanks for the responses.
Joe, The link you provided with the clear pictures was the most helpful. It was still a M.F. to get removed, but it finally worked out.
Now on to the next PROBLEM.
Old Mar 22, 2014 | 02:15 PM
NOTE: The domain name, "BuickPerformance.com" was purchased by GM and now leads to the main Buick.com site.
The new link is at "BuickPerfomanceClub.com."
Old Mar 23, 2014 | 05:38 AM
Sampson's Avatar
Eric, you must have ESP or I reached out to you through mental telepathy. I was searching this subject 2 days ago and came across this thread from 2009. I was really disappointed when the link went to the Buick site. The new link is great information. Thanks for the update!
Steve
Old Mar 23, 2014 | 06:32 AM
Thank MrOlds69 - he's the one who pointed me in the right direction.
dave1978
Jan 9, 2021 07:13 AM
ATrain1
Non-Olds Engines
Jun 29, 2012 12:58 PM
344870M
Aug 21, 2009 08:04 AM
Thuffner3
Dec 11, 2007 07:38 PM
