Old spot welds, Is there an easy way to find them?
Old Dec 11, 2007 | 10:49 AM
Thuffner3's Avatar
I can get to all of them most times. And rather than grind off a single layer of metal. I would rather find the welds and drill them out.
Thank you
Old Dec 11, 2007 | 12:28 PM
Dapapadon's Avatar
If the metal is still in good shape you can lightly grind or sand the paint off. The spot welds will show as circular depressions.
If the metal is rusty I ussually cut next to the lap joint on the scrap side. Get enough of the rusty metal out of the way so I can pry the joint open to find the spot welds. Some will pop or I can drill them with a spot weld cutter. Tougher ones I cut on both sides and keep prying, popping & cutting til I get to the end. Then go back and grind off the tough ones.
Hope this helps. Don
Old Dec 11, 2007 | 12:32 PM
Oldsguy's Avatar
Past Administrator
Here is a link to a thread that talks about it, read the post by "cadzook".
http://www.jalopyjournal.com/forum/s...5819&showall=1
Old Dec 11, 2007 | 04:10 PM
ozoneblue's Avatar
Follow Dans link Drill bits made for them
Old Dec 11, 2007 | 07:38 PM
Thuffner3's Avatar
Thanks guys, you have been quite helpful.
Rocket Richard
Body work
Jan 23, 2015 05:30 AM
smash72
Jun 26, 2014 04:41 PM
gearhead1218
Mar 23, 2014 06:32 AM
sammieolds
Drivetrain/Differentials
Jul 30, 2010 12:15 PM
Kidcutty
Brakes/Hydraulic Systems
15
Apr 2, 2010 06:33 PM
