Ignition lock cylinder
Old Mar 22, 2014 | 10:29 AM
kwhitehead's Avatar
How do you remove an ignition lock cylinder on a 71 cutlass if you don't have the key ?
Old Mar 22, 2014 | 11:06 AM
You have to remove the steering wheel, lock plate, and turn signal switch, which then gives you access to the spring loaded lock tab that holds the lock cylinder in place.
By the way, if you type lock cylinder removal into the search box on this site, you get all these threads with photos of how to do it...
https://classicoldsmobile.com/forums...l-problem.html
https://classicoldsmobile.com/forums...-easy-way.html
https://classicoldsmobile.com/forums...lumn-woes.html
Old Mar 22, 2014 | 12:38 PM
Note: The first thread that Joe posted is a good one.
Both of the others point you to a now-dead link that redirects to GM's Buick new-car website.
Old Mar 22, 2014 | 01:10 PM
mrolds69's Avatar
FYI The new Buick address for those dead links is the Buick Performance Club. The man who started the other address sold it to GM Buick division for $. The old info is all there still, it's a really nice site loaded w/ info and good for Olds, too.
Old Mar 22, 2014 | 02:18 PM
Thank you for that.
Actually, that club site has some nice write-ups.
Their simple answer to the perennial "How do I remove my back seat?" question is good.
The new steering column link is at "BuickPerfomanceClub.com."
Old Mar 22, 2014 | 02:25 PM
mrolds69's Avatar
I know...really good info on that Buick site and V8buick.com. I'm going to toss something up about date codes from the Buick site.
Old Mar 22, 2014 | 02:34 PM
It's back!!!
This used to be my go-to link for explaining the tilt column wobble fix and the lock cylinder removal photos, but it went dark a couple of years ago. I'm glad it's back up. Now bookmarked again.
Old Mar 22, 2014 | 02:36 PM
mrolds69's Avatar
It never really left Joe! GM made the guy an offer, he sold and just changed the name a little.
Old Mar 22, 2014 | 03:44 PM
kwhitehead's Avatar
lock is in thanks
Garikes
Mar 23, 2014 10:18 AM
johnnyhawthorn
Feb 12, 2014 11:47 AM
1Fastolds
Ninety-Eight
Jan 31, 2014 02:04 PM
randomarrival
Dec 22, 2012 12:28 PM
jread199
Nov 11, 2012 02:54 PM
