Under hood light
Old Mar 21, 2014 | 12:48 PM
spate51's Avatar
Under hood light
Where does the under the hood light tie in to the wiring harness? Or does it go to the power takeoff relay on the drivers side?
Old Mar 21, 2014 | 12:53 PM
Nop's Avatar
Nop
2-stroke 1-cylinder guy
On a 70 Cutlass it's wired to brown (side markers) with a connector very close to the engine bay connector below the brake booster.
* Only when lights are on
* Only when hood is openend (mercury switch)
See my signature, it's right/above the fuse panel.
Old Mar 21, 2014 | 01:02 PM
spate51's Avatar
Thanks. Car is a 69 350 S and I will look for that connector.
Old Mar 21, 2014 | 01:11 PM
Nop's Avatar
Nop
Had a look, I have no picture at hands.
You'll find it, use a flash light and look down the rear driver side corner of your engine bay around the booster. It's a standard one prong snap-lock GM connector in black - on a '70 Cutlass, that is.
Old Mar 21, 2014 | 01:36 PM
Actually, it's that way on all 68-72 Cutlii. It's a single wire with a single rectangular Packard 56 connector (female plastic connector body with a male spade terminal inside it). As noted, look under the booster.
Old Mar 21, 2014 | 01:50 PM
spate51's Avatar
Will do. Thanks to all.
Old Mar 22, 2014 | 11:45 AM
Nop's Avatar
Nop
Your order, Sir:
Old Mar 22, 2014 | 11:55 AM
Your order, Sir:
Well done. Nice shot.
Old Mar 22, 2014 | 04:04 PM
spate51's Avatar
Thanks again. The reason I couldn't find it is because when I was rebuilding things a couple of years ago, I put the connection behind the firewall. Took part of the ac ducts apart and there it was. Fished it out through a firewall grommet and it works fine.
heritageadam
Nov 29, 2012 09:02 PM
matchek
Oct 1, 2012 12:42 PM
Rocket331
Jun 2, 2012 08:51 PM
DRXOLDS
Nov 13, 2011 08:00 PM
69'442
Sep 17, 2011 01:50 AM
