DIFFERENTIAL SWAP
Old Sep 10, 2009 | 04:39 PM
roscoep41's Avatar
DIFFERENTIAL SWAP
I have a 71 cutlass s, 350, auto, non-posi 2.56 gears.I want to put a diff from a 70 chevelle. This is a posi with 3.08 gears. what kind of trouble will I have when I try to put it in.
Old Sep 10, 2009 | 04:44 PM
svnt442's Avatar
If it's the entire axle it should be a direct swap. Are they both 10 bolts?
Old Sep 10, 2009 | 05:15 PM
roscoep41's Avatar
Yeah they are both 10 bolts.I had to make new spring seats and weld them on because on the cutlass they sit farther ahead than on the chev.the lower control arm hangers look like they are farther apart on the chev I think I should move them closer before I try to install so the control arms will fit without a problem.
Old Sep 10, 2009 | 06:01 PM
The rear suspension, control arms, and spring seats are IDENTICAL on all 68-72 A-body cars. If you had to move the spring seats, one of the two axles is not from an A-body.
Old Sep 13, 2009 | 08:17 AM
roscoep41's Avatar
I'm pretty sure that the rear end in the car is original.The one that I want to put in, I got from under a circle track car.I was told it was out of a chevelle.I'm having a hard time reading the ID numbers on the axle housing.The rear end looks the same other than some slight differences in measurements
Old Sep 13, 2009 | 12:47 PM
svnt442's Avatar
The measurements should be the same between the two axles period.
Old Oct 14, 2009 | 03:45 PM
Warhead's Avatar
Do not be surprised if you need a crossover u-joint.
HitTheHole
Drivetrain/Differentials
Aug 7, 2014 05:47 PM
cutlassclay
Feb 18, 2014 08:56 AM
leepear
Nov 9, 2011 10:10 AM
henryk8398
Feb 26, 2010 02:43 PM
Samson
Apr 9, 2009 05:39 AM
