Type O Rear Differential Swap
Old Dec 15, 2013 | 12:33 AM
HitTheHole's Avatar
Is this all I need to convert my 1970 Olds non-posi Type O rear end to a posi?http://www.billsgear.co/traction-dev...pline-12-bolt/
Old Dec 15, 2013 | 06:50 AM
oldstata's Avatar
Justin
That's pricy I would check with 507olds or monzaz I am sure they can help you out
Old Dec 15, 2013 | 07:36 AM
oldsmobiledave's Avatar
or
$65.00 cheaper @ Supercars Unlimited.
http://www.supercarsunlimited.com/12...iers-i275.aspx
or you can contact CO members on here to buy direct from them @ better prices.
Old Dec 15, 2013 | 08:16 AM
Octania's Avatar
Installation may require additional parts, tools, and expertise.
Mightaswell the bearings, right?
No actual-part photo and no product reviews yet rubs me the wrong way.
Old Dec 15, 2013 | 10:38 AM
HitTheHole's Avatar
Thank you for pointing out a lower price but I'm most concerned with getting the correct and complete parts. Will I need other parts in addition to the carrier? Does it make sense to replace other parts when doing a swap?
Old Dec 15, 2013 | 10:40 AM
oldstata's Avatar
Justin
Axle bearings and seals monzaz does this everyday if memory serves me he quoted me 600 for posi bearings and rebuild kit
All the posi unit is for these is a ford 8.8 machined to fit in olds housing
Old Dec 15, 2013 | 12:15 PM
more
DING DING DING...We have a winner. This is EXACTLY what I did when I converted the original 3.23 open in my 1969 Olds 442 to a posi. Many others on here have done the same. Deal with other members of this forum & you will come out ahead. Jim is excellent to deal with & prices are fair.
That said I have done business with Supercars & always was satisfied with the service & parts received. I got a 3.42 crown & pinion from them in June of 2012 (I think it must have been the last one in captivity).
Old Dec 15, 2013 | 01:24 PM
Originally Posted by HitTheHole
Is this all I need to convert my 1970 Olds non-posi Type O rear end to a posi? http://www.billsgear.co/traction-dev...pline-12-bolt/
If you currently have 3.08 to 3.23 gears, then this carrier will work. That ad doesn't say if the carrier has new bearings installed, so if it doesn't you will need new carrier bearings and get them pressed onto the carrier. I would also replace the axle bearings and seals when it's apart since they will be readily accessible during the carrier swap.
Old Dec 15, 2013 | 05:57 PM
76olds's Avatar
Hookers under Hood
X3 Jim ( monzaz ) is excellent to deal with, I just did a deal with Him, not only are his prices awesome, he also lowered the price some because the shipping to my place in Canada was up there. New Eaton Posi unit , Eaton HD install kit , 3:42 pinion and gears, Bearings and seals.
Old Dec 17, 2013 | 05:51 AM
monzaz's Avatar
Posi and stuff for the 12 bolt O
WOW 664.00 MAn that is A LOT! I have the same unit on Ebay for 479.00
Eaton type.
They are charging too much for the machine work for sure. Jim
PM Will help you out.
Old Dec 20, 2013 | 05:16 AM
507OLDS's Avatar
The posi unit that Jim sells is NO different than the ones that SuperCars sell,or Bill's Gears sell,or I sell. They are all remachined/modified 8.8" Ford units.
Nobody makes a new casting for the O-axle. That is also why the unit has two sets of ring gear holes.The other set was the Ford pattern.
Old Dec 22, 2013 | 07:10 AM
monzaz's Avatar
Differences
wELL THERE ARE SOME DIFFERENCES- They sell the trac lock (S Spring) mine is based off the Eaton unit which i consider better. That is the NEW units I sell. Jim
I normally keep a verity of reconditioned and new and can even do true trac posi units BUT with the stagnate supply of GEARS! I have been not producing as many. Jim
Old Aug 7, 2014 | 05:41 PM
cdoering's Avatar
Looking for a 3:23 posi for my 70 442 W30. Call me to discuss price and what is included
Chris 314-495-1700
Old Aug 7, 2014 | 05:47 PM
70cutty's Avatar
Beer Connoisseur
Chris just call Jim, you can find his number on jdrace.com
rcorrigan5
May 3, 2015 10:15 AM
Otto Skorzeny
Drivetrain/Differentials
Mar 13, 2014 07:16 PM
L77F85
16
Nov 29, 2013 06:19 AM
Samson
Apr 9, 2009 05:39 AM
Flamed67
Oct 20, 2008 09:40 AM
