- Spring Comprssor Toil Front Coil
- OAI on 69 cutlass 350 rocket
- wooden steering wheel
- 1969 cutlass rear 8.2 ?
- Disc brake conversion doesn't fit on SSII 14" X 7"wheels
- GM parts interchange info
- '61 394 valve train. I'm at a loss and I can't find solid info.
- Help decoding a 1956 Super 88 Cowl tag
- Rochester 4gc carburetor questions
- 68 cutlass hood differences (frame)
- Replacement Springs and Ride Height
- Gauge/Tach/Clock Restoration:
- wiring harness for 64 cutlass
- Cowl tag help... '70 442
- 67 electric windows
- Front power disc brakes question
- 72 A body seat belt reminder light
- Cleaning Plastic in Engine compartment
- Drive shaft length
- 68-72 bb?
- Windshield replacement
- OEM part numbers
- washer reservoir.
- Alternator painted black..?
- Anyone have 1966 cutlass convertible diagrams
- Another possible BUY- 1970 W30 - Question on price
- 1970 w31
- Intake manifold bolts
- '69 Hurst/Olds fuel pump
- 65-67 400cid application
- Air cleaner ID please
- Oil Pan Gaskets
- Valve Cover Breather Pipes
- Found Some Possible Interesting Parts Ref
- Rocket 350
- power trunk release Rod for 66/67 Cutlass
- Brake unit problem
- 1982 Regency Brougham Fuel Pump
- Fuel Stabilizers
- edelbrock carbs
- stock power steering box ratio
- starving for gas
- Body Mount Confusion
- Choking on the costs to divorce
- Blower Relay Color
- '66 442 PW & PDL Switch locations
- Best Oil Grade
- o2 sensors in older cars
- Gas Tank Date Codes
- Flarestat interchange
- Heater core
- 57 olds super 88 floor and trunk issues
- 67 fuel gauge issues
- 1965 starfire convertible
- Vin Decoding
- Help with power trunk release for 68 442
- '71 Antenna Location
- 1968 Factory Front-end Alignment Specs
- gas pedal thing?
- 1970 Cutlass convertible radio question
- 1970 Cutlass interior color question
- NOS/Reproduction V belts for 350's
- Pre lube tool
- 72 Cutlass dome light wiring question
- Trunk Latch Vacuum Hose Routing & clips
- 70 CS hazard flasher knob and E-brake release lever
- dayco belts and part numbers
- Getting my window up without power
- Can't ID circuit/fuse or find replacement
- 62 Ninety Eight sway bar bushings
- 69 Hood hinge nuts
- Fuse Panel Bolt
- Water pump length?
- 65 Starfire front and rear bumper brackets
- 66 cutlass 455 swap with Holley intake,to tall!
- Temperature idiot light
- 5qt. vs 4 qt. Pan on stock L69
- 70-72 Radiator Top Plate differences Question
- 1965 Starfire Grille compatability question
- Welding Question
- going without a/c
- 1987 442 engine conversion
- 1965 olds 88 2dr coupe
- Differential Code 8L 63 Starfire
- Vacuum and fuel pump connection questions.
- Hydraulic Hose for Power Window
- Temp guage gose almost to hot then back to mid
- 1966 cutlass/442 modern rim / tire size
- V-8 330 timing chain
- 62 Starfire original trim confusion
- '71 and '72 Rear Window Defogger Red Dot
- Do I have the correct radiator top plate?
- 56 olds turn lever problem, need help
- 425 manifolds
- Dynomax exhaust with pypes down pipes?
- 1966 Cutlass / 442 side trim color
- Power steering leak
- pre-load on front wheel bearings
- 1986 )Olds 98 Regency Brogham
- 67 toronado 425 quadrajet
- 72 Cruise Control plating colors
- 1970 98 weight distribution
- 69 Olds Cutlass Front hood molding
- Delta 88 part scavenger hunt
- Chassis parts usage across models
- 371 olds
- 4 spd. carpet
- 67 Toronado Air Conditioning Hoses
- KM pulley now reproduced?
- 455 in a 1956 oldsmobile info needed
- aluminum intake for a 350 olds
- Scissor top reduction gear replacement.
- The right tools?
- $50.00 mistake
- relay problem/confusion
- '72 455 AC Pulleys
- relay rod or center link
- 79 cutlass calias 2 spoke sport wheel
- Pitman arm question
- 70 Olds 442 Rear Window Defogger Switch
- 71 Cutlass Radio dimensions?
- Dual exhaust question
- 1969 cutlass parking brake lever
- '68 Front Bumper brackets -'69 same?
- shift indicator needle 68 98
- Reference for GM master cylinder castings/codes?
- Coasting in Neutral a NO NO says manual.
- 1969 olds kicking my a$$
- ground up parts questions[any and all help is appreciated]
- Autometer Gauge question
- Driveshaft Stripe Color
- spare tire hold down rod
- 1965 octane requierments
- Engine compartment markings
- dash / gauge lights replacement
- oil pressure sensor location
- oil change 72 Toro 55k possibly has Mobile one?
- PCV valve
- Timing Mark on Olds 425
- 1970 Cutlass SX Radiator top plate, Which style is right?
- Water pump bolts on BBO
- Speedo
- Air Cleaner lid seal 70-72 4bbl
- Spark plug reading needed
- 1965 cutlass radiator top plate
- Decal placement under hood of 57 Oldsmobile Super 88
- Mounting Aluminum Radiator in 1967 Cutlass
- Starter 1970 455
- windshield or 63 F85
- 1973 Delta Royale convertible door windlace
- 1971 442 Convertible Top Replacement Vendor
- 68 Olds 350 build out
- New fuel tank 17 or 20 gallons?
- Setting the Dwell on Points
- 62 DYNAMIC signal cancelling cam
- replacing ball joints
- spark plugs= needle in a hay stack!!
- Help
- AC problems, bad POA valve????
- Dumping Pertronix Ignitor for MSD system
- Core support?
- Repro Front Bumpers
- 1969 442 Radiator / Top Plate Measurements
- All fiberglass OAI hood
- what is this cable do??
- overheating on 65 442 400
- Block Bypass hose from thermo housing to water pump ?
- Hy-Per Lube Super Coolant
- T-3 head lights
- 1957 98 2-door hardtop
- 1970 Cutlass Convertible ... Fuel Gauge Pegged Right
- I doubt it, but maybe
- 67 toronado
- guage clusters
- Tri carb question
- water pump
- Cam ID
- Steering wheel lock
- steering column interchange
- 1952 Super 88 Speedometer
- 1962 Starfire Windshield Washer Bottle ????
- A/C Vacuum Connector
- Motor Mount Condition - Normal or not?
- weights and measures
- 1968 Shift Cable Length?
- Brake lights
- tranny question
- Diagnostic basic's ?
- B&M Shifter questions
- Rubbish Accelerator Pump Cup
- dual exhaust kits for manifolds
- Cam Timing
- Working on a '56 Super 88 w/air
- 1966 442 decklid trim hole locations
- 70 Cutlass 350 4bbl - square or spread bore?
- Installing a convertible top
- Manual conv top release?
- Fender script holes
- How difficult is it to install a 455 in a 350 car?
- What order to do a "rolling" restoration?
- timing trouble '71 455
- rear diff.
- scott allen on face book..needs slim jim dipstick
- Voltage Regulator Location '73 Delta 88
- Headlight switch removal
- 1957 replacement floor pans please
- 1971 F85 trunk trim question
- assembly manual bolt ID reference!
- Fan shroud
- Balancer Identification
- Proper proceedures for Shell Swaps
- 1972 Conv Top Boot
- Park Light problem
- Radiator Supplier - Help!
- Distributor Removal and Recurve
- 70 F-85 question
- Fuel Injection delema
- Quad Air Horn Removal
- Cowl tag help
- 73 old delta 88
- 1969 hurst olds survivor
- Hedman shorty headers?
- 1964 Olds 98 holiday cp need help
- Decoding the vin and cowl info
- rebuildt carbs
- 410668 radiator hose
- Thanks to the previous owner
- EFI conversion
- - - paint code
- FYI ARP head bolt torque specification different
- Heater coolant return line to passenger side, near firewall intake manifold restricti
- WTD: dimensions of 68-72 Cutlass AC condenser
- From non air to Air 70 Cutlass Rallye 350
- Heater core repair for1968 Cutlass S convertible
- Wich Transmission under a 62 Starfire?
- Olds/Pontiac hyd.lifter interchangeability
- 62 starfire thermostat housing
- cross members
- 51 303 Head bolt tightening pattern
- measuring cylinder bore
- Flat Bed "Towing"
- Reproduction vs Original Parts
- rear spoiler
- New Engine Start
- Wiring a MSD Ignition to Starter
- decoding qjet carbs
- 2GGC carb
- Oil in breather
- strange wires?
- Posi track conversion
