Mounting Aluminum Radiator in 1967 Cutlass
Hey guys, well my old steel radiator had a nice hole in it so I went ahead and ordered a be cool radiator and external tranny cooler from Summit. Just wondering if anybody has any helpful advice on how to mount it in my 67 cutlass supreme. Thanks!
http://www.summitracing.com/parts/bci-10008
Here's the link to the radiator. Just got delivered today so I'll check it out when I get home but I almost assume It doesn't have factory mounting points.
Just fyi, Radiator Barn offers an aluminum radiator with plastic end tanks that is a direct replacement for about $100. It also has the factory type trans oil cooler. Make sure to cut off the small OD end of the top hose fitting, leaving the big OD base part of it.
Also, your stock radiator is copper with brass tanks, not steel.
jkoester122
Sep 8, 2011 07:48 PM
