Mounting Aluminum Radiator in 1967 Cutlass
Old Aug 24, 2013 | 12:29 PM
H8D-67's Avatar
Hey guys, well my old steel radiator had a nice hole in it so I went ahead and ordered a be cool radiator and external tranny cooler from Summit. Just wondering if anybody has any helpful advice on how to mount it in my 67 cutlass supreme. Thanks!
Old Aug 24, 2013 | 12:41 PM
Probably some pictures of it would help. Is there any instructions with the radiator?
Old Aug 24, 2013 | 05:03 PM
H8D-67's Avatar
http://www.summitracing.com/parts/bci-10008
Here's the link to the radiator. Just got delivered today so I'll check it out when I get home but I almost assume It doesn't have factory mounting points.
Old Aug 24, 2013 | 08:12 PM
Doesn't look that bad, I wonder if it comes with an install kit.
Old Aug 25, 2013 | 06:38 AM
Run to Rund's Avatar
Just fyi, Radiator Barn offers an aluminum radiator with plastic end tanks that is a direct replacement for about $100. It also has the factory type trans oil cooler. Make sure to cut off the small OD end of the top hose fitting, leaving the big OD base part of it.
Also, your stock radiator is copper with brass tanks, not steel.
tocicar8825
Sep 21, 2021 07:10 AM
Pewter442
Feb 13, 2015 09:14 AM
1k442
Mar 18, 2013 08:49 AM
jkoester122
Sep 8, 2011 07:48 PM
muddy
Jun 10, 2006 04:24 AM
