Pitman arm question
Old Sep 16, 2013 | 07:13 PM
Napoleon1991's Avatar
Pitman arm question
Hi, is this gap between the pitman arm and the steering box normal? It seems pretty big and not the entire width of the steering box splines are in contact with the pitman arm. Thanks in advance for any help. (sorry about the sideways pic)
Old Sep 16, 2013 | 07:38 PM
Yes.
Old Sep 16, 2013 | 07:52 PM
It won't fall off if that's what you're worried about. That nut is torqued to somewhere around 180 ft/lbs if memory serves.
Old Sep 16, 2013 | 09:54 PM
The nut was hand tight so i torqued it down to 100 ft lbs (according to chiltons). Should i torque it all the way to 180?
Old Sep 17, 2013 | 02:56 AM
Why would you rely on Chilton's for information?
The CSM says 150 ft/lbs.
Old Sep 17, 2013 | 07:18 AM
To the O.P.'s original question, the splines on the steering box are tapered, so the pitman arm only goes on until it wedges on the tapered splines, then stops. The gap is irrelevant.
Old Sep 17, 2013 | 08:58 AM
Double check that Eric, I thought your number was low so I checked the 69 CSM and the Pitman shaft nut is supposed to be between 180 and 210 ft/lbs whether PS or manual steering. See page 9-36 of the 69 CSM? Where in the CSM did you find the 150 number? Maybe I'm missing something.
Old Sep 17, 2013 | 09:25 AM
Ha. Figures.
I found my number in the '68 CSM under Torque Values at the end of the Steering chapter.
Usually these numbers are the same regardless of year, but every now and then you get a wise guy, like the early years low harmonic balancer torques.
I agree you should go with the higher value - since the gear box didn't change, I'd suspect they increased the torque in response to experience in the field.
DaveD65
Apr 22, 2014 06:10 PM
KevinBN7
Oct 29, 2010 06:35 AM
scrappie
Feb 13, 2010 04:41 PM
Brodyvonsickboy
Oct 15, 2009 10:59 AM
J-(Chicago)
May 29, 2008 04:30 PM
